Home » Eclipse Projects » NatTable » not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows
not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989741] Fri, 07 December 2012 13:38 Go to next message
karishma Agarwal is currently offline karishma AgarwalFriend
Actually I have created a Nattable which is based on Tree structure and has cells which are spanning rows. I want to attach a combined painter(Text Painter and TreeCheckBoxPainter) to that spanning cell. I am not able to achieve this.I am doing this for combining the painters.
configRegistry.registerConfigAttribute(
CellConfigAttributes.CELL_PAINTER,
new BackgroundPainter(
new CellPainterDecorator(
new TextPainter() {
protected String convertDataType(ILayerCell cell, IConfigRegistry configRegistry) {
//Datum dataValue = (Datum) cell.getDataValue();
return "Blackberry 5.0 and above";
CellEdgeEnum.BOTTOM,
serverSideBB5CheckBoxPainter
DisplayMode.NORMAL,
BuildTreeLayer.BB_5_SPA_LABEL
and I have created a DataProvider which implements ISpanningDataProvider and extends GlazedListDataProvider and I have overridden the getCellByPosition() method.Only the CheckBox is getting painted. The Text is not getting painted. Am I missing something else to achieve this??
Karishma Agarwal
[Updated on: Fri, 07 December 2012 13:40]
Report message to a moderator
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989743 is a reply to message #989741] Fri, 07 December 2012 13:39 Go to previous messageGo to next message
No Message Body
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989947 is a reply to message #989743] Mon, 10 December 2012 08:12 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
never tried spanning in a tree before. Is spanning working with a simple TextPainter there?
Greez,
Dirk
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989951 is a reply to message #989947] Mon, 10 December 2012 08:47 Go to previous messageGo to next message
Thanks for ur fast reply. Actually spanning is working with a simple checkBox painter. I havent tried with a simple TextPainter. And also since the text which I am passing is bit large to fit in one line in a row.so It is expanding the height of the row. That means internally it is trying to paint the text but something is missing due to which the text is not visible.
Karishma
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989952 is a reply to message #989951] Mon, 10 December 2012 08:51 Go to previous messageGo to next message
if a simple CheckboxPainter is working with spanning in a tree, and the TreeCheckboxPainter doesn't, I'll assume it is a bug. Could you please file a bug in bugzilla so it can be tracked and investigated correctly?
Dirk
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989954 is a reply to message #989952] Mon, 10 December 2012 08:55 Go to previous messageGo to next message
Sorry, actually by CheckBoxPainter, i meant TreeCheckBoxPainter only. TreeCheckBoxPainter alone is working fine.But when combining with TextBox, its not showing the desired results.
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989956 is a reply to message #989954] Mon, 10 December 2012 09:11 Go to previous messageGo to next message
Oh, sorry, so I missunderstood your issue. Are you sure that the label you attached that painter to is set correctly?
Re: not able to combine Text Painter and TreeCheckBoxPainter in a cell which spans multiple rows [message #989964 is a reply to message #989956] Mon, 10 December 2012 09:52 Go to previous message
Thanks Dirk. Some problem was there with my labels. Its working fine now.
Previous Topic:How to change the font?
Next Topic:Change the cursor style for a table cell?
Current Time: Mon Feb 24 16:00:41 GMT 2020
Powered by FUDForum. Page generated in 0.03722 seconds
