Re: Native java code Tools example [message #989610 is a reply to message #989552] |
Thu, 06 December 2012 22:57 |
Hi Robert,
This article provides an example that demonstrates how to create a new Java tool; SampleTool is not a real tool included in the Epsilon distribution. As such, to use it you'll need to create it first by going through the steps of the article, launch a new Eclipse instance and use it from there.
Dimitris
Re: Native java code Tools example [message #989679 is a reply to message #989610] |
Fri, 07 December 2012 09:50 |
Robert Wilterdink Messages: 5 Registered: December 2012 |
Hi Dimitris,
Let me clearify this. I downloaded the example, imported the plugin project in Eclipse & ran a new Eclipse instance (from the first Eclipse instance). The plugin is 'found', since I checked this in the installation details (Help -> About Eclipse).
However, the SampleTool is not found in the script.
Robert
[Updated on: Fri, 07 December 2012 09:50] Report message to a moderator
Re: Native java code Tools example [message #989717 is a reply to message #989679] |
Fri, 07 December 2012 12:23 |
Hi Robert,
This seems to be working fine for me. Could you perhaps check if you can instantiate any of the other tools (see Window->Show view...->Tools for a complete list of available tools)?
Dimitris
FUDForum. Page generated in 0.03179 seconds
