Errors appear and disappear depending on if file is open [message #989339] |
Wed, 05 December 2012 17:19 |
Wesley Miller Messages: 4 Registered: May 2011 |
I have an inherited machine vision (opencv/pylon) project that seems to build with 0 errors, 120 warnings, etc. To accomplish this I:
- "Select All" in the "problems" window then Delete and answer Yes.
- Project -> Clean -> Clean Selected,
- Click my projectname, (and build selected project after clean is also checked).
- Enter
The Console Window shows no errors (searched with Find). (it also shows that CameraBuffer.cpp compiled with no errors -- see below)
The Problems Window show 0 errors, 120 warnings ....
Now, I open one of my files (CameraBuffer.cpp). The file shows 7 errors, the Problems WIndow updates and shows the 7 errors.
Where did those come from. The file is in my source directory (src) and other stuff in there is compiling ok.
I tried just cleaning and compiling CameraBuffer.cpp to see what happened. While the build worked find with the Clean/build (aabove) the single Compile (right click on filename, compile this file) I get errors related to the compile step trying to do a pkg-config --cflags opencv, but I suspect that's a different question.
I also note that the othdr cpp files in the src directory don't offer me the chance to right-click/clean/build.
So, can someone tell me what's happening? Is eclipse remembering old errors that are tied to the file but not seen by the project? Is the project missing the errors? Do I need to just delete the file from the project and then remake it?
Tnx, Wes
FUDForum. Page generated in 0.04098 seconds
