Home » Eclipse Projects » NatTable » Using FilterList for tree in NatTable
Using FilterList for tree in NatTable [message #989156] |
Tue, 04 December 2012 21:58 |
Rashmy A Messages: 149 Registered: July 2009 |
I have a requirement for tree display in NatTable. So started out with the example TreeGridExample that is provided by NatTable. Things look good but I wanted to add filtering support.
Modified the TreeGridExample to support filters
-Wrapped the TreeList <Datum> treeList in FilterList
-Added TextMatcherEditor
See code below for FilterTreeGridExample.java (unfortunately cannot attach file in this forum)
If you launch the attached example code, you will see that it does filter out things but the UI is messed up. It shows expand/collapse images incorrectly.
Now, I'm assuming this is because the TreeLayer actually shows/hides things based on its own list of 'hiddenRowIndexes'. Could you please suggest how I should proceed? Do I stop using FilterList and instead fire TreeExpandCollapseCommand to show/hide rows?
public class FilterTreeGridExample extends AbstractNatExample {
protected static final String NO_SORT_LABEL = "noSortLabel";
StandaloneNatExampleRunner.run(800, 400, new FilterTreeGridExample());
public Control createExampleControl(Composite parent) {
ConfigRegistry configRegistry = new ConfigRegistry();
configRegistry.registerConfigAttribute(SortConfigAttributes.SORT_COMPARATOR, new DefaultComparator());
// Underlying data source
createDatums();
EventList<Datum> eventList = GlazedLists.eventList(datums.values());
SortedList<Datum> sortedList = new SortedList<Datum>(eventList, null);
// TreeList <RowDataFixture> treeList = new TreeList<RowDataFixture>(eventList, new RowDataFixtureTreeFormat(), new RowDataFixtureExpansionModel());
String[] propertyNames = new String[] { "foo", "bar" };
IColumnPropertyAccessor<Datum> columnPropertyAccessor = new ReflectiveColumnPropertyAccessor<Datum>(propertyNames);
// Column header layer
IDataProvider columnHeaderDataProvider = new DefaultColumnHeaderDataProvider(propertyNames);
DataLayer columnHeaderDataLayer = new DefaultColumnHeaderDataLayer(columnHeaderDataProvider);
ISortModel sortModel = new GlazedListsSortModel<Datum>(
sortedList,
columnPropertyAccessor,
configRegistry,
columnHeaderDataLayer);
final TreeList <Datum> treeList = new TreeList<Datum>(sortedList, new DatumTreeFormat(sortModel), new DatumExpansionModel());
GlazedListTreeData <Datum> treeData = new DatumTreeData(treeList);
//-----------START: CODE TO SUPPORT FILTER -----------//
//Create filter
TextFilterator textFilterator = new TextFilterator<Datum>()
public void getFilterStrings(List<String> arg0, Datum arg1)
arg0.add( arg1.foo );
CompositeMatcherEditor groupMatcherEditor = new CompositeMatcherEditor<Datum>();
groupMatcherEditor.setMode( CompositeMatcherEditor.OR );
TextMatcherEditor matcher1 = new TextMatcherEditor<Datum>(
textFilterator );
matcher1.setMode( TextMatcherEditor.CONTAINS );
matcher1.setFilterText( new String[] { "A" } );
TextMatcherEditor matcher2 = new TextMatcherEditor<Datum>(
textFilterator );
matcher2.setMode( TextMatcherEditor.EXACT );
matcher2.setFilterText( new String[] { "C.1" } );
TextMatcherEditor matcher3 = new TextMatcherEditor<Datum>(
textFilterator );
matcher3.setMode( TextMatcherEditor.EXACT );
matcher3.setFilterText( new String[] { "root2" } );
TextMatcherEditor matcher4 = new TextMatcherEditor<Datum>(
textFilterator );
matcher4.setMode( TextMatcherEditor.CONTAINS );
matcher4.setFilterText( new String[] { "Y" } );
groupMatcherEditor.getMatcherEditors().add( matcher1 );
groupMatcherEditor.getMatcherEditors().add( matcher2 );
groupMatcherEditor.getMatcherEditors().add( matcher3 );
groupMatcherEditor.getMatcherEditors().add( matcher4 );
EventList<MatcherEditor<Datum>> matcherEditors = new BasicEventList<MatcherEditor<Datum>>();
matcherEditors.add( groupMatcherEditor );
CompositeMatcherEditor filterMatcherEditor = new CompositeMatcherEditor<Datum>();
filterMatcherEditor.getMatcherEditors().addAll( matcherEditors );
filterMatcherEditor.setMode( CompositeMatcherEditor.OR );
FilterList<Datum> filterList = new FilterList<Datum>( treeList );
filterList.setMatcherEditor( filterMatcherEditor );
//-----------END: CODE TO SUPPORT FILTER -----------//
GlazedListsDataProvider<Datum> bodyDataProvider = new GlazedListsDataProvider<Datum>(filterList, columnPropertyAccessor);
DataLayer bodyDataLayer = new DataLayer(bodyDataProvider);
// Body layer
ColumnReorderLayer columnReorderLayer = new ColumnReorderLayer(bodyDataLayer);
ColumnHideShowLayer columnHideShowLayer = new ColumnHideShowLayer(columnReorderLayer);
SelectionLayer selectionLayer = new SelectionLayer(columnHideShowLayer);
// Switch the ITreeRowModel implementation between using native grid Hide/Show or GlazedList TreeList Hide/Show
// TreeLayer treeLayer = new TreeLayer(selectionLayer, new TreeRowModel<Datum>(treeData), true);
TreeLayer treeLayer = new TreeLayer(selectionLayer, new GlazedListTreeRowModel<Datum>(treeData), false);
ViewportLayer viewportLayer = new ViewportLayer(treeLayer);
ColumnHeaderLayer columnHeaderLayer = new ColumnHeaderLayer(columnHeaderDataLayer, viewportLayer, selectionLayer);
// Note: The column header layer is wrapped in a filter row composite.
// This plugs in the filter row functionality
ColumnOverrideLabelAccumulator labelAccumulator = new ColumnOverrideLabelAccumulator(columnHeaderDataLayer);
columnHeaderDataLayer.setConfigLabelAccumulator(labelAccumulator);
// Register labels
SortHeaderLayer<Datum> sortHeaderLayer = new SortHeaderLayer<Datum>(
columnHeaderLayer,
sortModel,
false);
// Row header layer
DefaultRowHeaderDataProvider rowHeaderDataProvider = new DefaultRowHeaderDataProvider(bodyDataProvider);
DefaultRowHeaderDataLayer rowHeaderDataLayer = new DefaultRowHeaderDataLayer(rowHeaderDataProvider);
RowHeaderLayer rowHeaderLayer = new RowHeaderLayer(rowHeaderDataLayer, viewportLayer, selectionLayer);
// Corner layer
DefaultCornerDataProvider cornerDataProvider = new DefaultCornerDataProvider(columnHeaderDataProvider, rowHeaderDataProvider);
DataLayer cornerDataLayer = new DataLayer(cornerDataProvider);
// CornerLayer cornerLayer = new CornerLayer(cornerDataLayer, rowHeaderLayer, columnHeaderLayer);
CornerLayer cornerLayer = new CornerLayer(cornerDataLayer, rowHeaderLayer, sortHeaderLayer);
// Grid
GridLayer gridLayer = new GridLayer(
viewportLayer,
// columnHeaderLayer,
sortHeaderLayer,
rowHeaderLayer,
cornerLayer);
NatTable natTable = new NatTable(parent, gridLayer, false);
natTable.setConfigRegistry(configRegistry);
natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
natTable.addConfiguration(new HeaderMenuConfiguration(natTable));
natTable.addConfiguration(new DefaultTreeLayerConfiguration(treeLayer.getModel()));
natTable.addConfiguration(new SingleClickSortConfiguration());
// Uncomment to see the native tree list printed to stout.
// printTree(treeList, treeData);
natTable.configure();
return natTable;
private static class DatumTreeData extends GlazedListTreeData<Datum>{
public DatumTreeData(TreeList<Datum> treeList) {
super(treeList);
public String formatDataForDepth(int depth, Datum object) {
return object.getFoo();
private static class DatumTreeFormat implements TreeList.Format<Datum> {
private final ISortModel sortModel;
public DatumTreeFormat(ISortModel sortModel) {
this.sortModel = sortModel;
public void getPath(List<Datum> path, Datum element) {
path.add(element);
Datum parent = element.getParent();
while (parent != null) {
path.add(parent);
parent = parent.getParent();
Collections.reverse(path);
public boolean allowsChildren(Datum element) {
return true;
public Comparator<? extends Datum> getComparator(int depth) {
return new SortableTreeComparator<Datum>(GlazedLists.beanPropertyComparator(Datum.class, "foo"), sortModel);
private static class DatumExpansionModel implements TreeList.ExpansionModel<Datum> {
public boolean isExpanded(Datum element, List<Datum> path) {
return true;
public void setExpanded(Datum element, List<Datum> path, boolean expanded) {
private void printTree(TreeList <Datum> treeList, ITreeData<Datum> treeData){
System.out.println(treeList.size());
for (int i = 0; i < treeList.size(); i++) {
final Datum location = treeList.get(i);
final int depth = treeList.depth(i);
final boolean hasChildren = treeList.hasChildren(i);
final boolean isExpanded = treeList.isExpanded(i);
for (int j = 0; j < depth; j++)
System.out.print("\t");
if (hasChildren)
System.out.print(isExpanded ? "- " : "+ ");
else
System.out.print(" ");
System.out.println(treeData.formatDataForDepth(depth, location));
public class Datum {
private final Datum parent;
private String foo;
private int bar;
public Datum(Datum parent, String foo, int bar) {
this.parent = parent;
this.foo = foo;
this.bar = bar;
public Datum getParent() {
return parent;
public String getFoo() {
return foo;
public int getBar() {
return bar;
public String toString() {
return "[" +
"parent=" + parent +
", foo=" + foo +
", bar=" + bar +
private Map<String, Datum> datums = new HashMap<String, Datum>();
private void createDatum(String parent, String foo, int bar) {
Datum datum = new Datum(datums.get(parent), foo, bar);
datums.put(foo, datum);
private void createDatums() {
createDatum(null, "root", 1);
createDatum("root", "A", 10);
createDatum("A", "A.1", 100);
createDatum("A", "A.2", 110);
createDatum("A", "A.3", 120);
createDatum("root", "B", 20);
createDatum("B", "B.1", 200);
createDatum("B", "B.2", 210);
createDatum("root", "C", 30);
createDatum("C", "C.1", 330);
createDatum("C", "C.2", 370);
createDatum("C", "C.3", 322);
createDatum("C", "C.4", 310);
createDatum("C", "C.5", 315);
createDatum(null, "root2", 2);
createDatum("root2", "X", 70);
createDatum("X", "X.1", 700);
createDatum("X", "X.2", 710);
createDatum("X", "X.3", 720);
createDatum("root2", "Y", 80);
createDatum("Y", "Y.1", 800);
createDatum("Y", "Y.2", 810);
createDatum("root2", "Z", 90);
createDatum("Z", "Z.1", 900);
createDatum("Z", "Z.2", 910);
createDatum("Z", "Z.3", 920);
createDatum("Z", "Z.4", 930);
createDatum("Z", "Z.5", 940);
Rashmy
[Updated on: Tue, 04 December 2012 21:59] Report message to a moderator
Current Time: Thu Apr 25 10:48:32 GMT 2024
Powered by FUDForum. Page generated in 0.02562 seconds
