Re: Eclipse 4 RCP build tabs immediately [message #989153 is a reply to message #989123] |
Tue, 04 December 2012 21:26 |
John Steele Messages: 50 Registered: January 2010 |
Member |
That's an interesting inquiry. As you know, one of the big insensitives for adding a view to the plugin.xml is that the view, and it's companion code, are not loaded or instantiated until necessary (lazy).
You could create your own perspective, add views to it, and then set their visibility to true, which will in turn cause them to be created once the perspective is opened.
1) Create a perspective, and add it to the org.eclipse.ui.perspective extension.
2) Create a view, and add it to the org.eclipse.ui.views extension.
3) Add an extension to the org.eclipse.ui.perspectiveExtension associated with the perspective you created.
4) Add the views to it, and set visibility flag to true.
Now, when the perspective is opened all those views will be opened, thus causing the views to be created.
Re: Eclipse 4 RCP build tabs immediately [message #989851 is a reply to message #989172] |
Sat, 08 December 2012 13:17 |
Daniel Stingl Messages: 11 Registered: November 2012 |
Thank u for your help John Steele, I am afraid I was not able to follow those steps accordingly and it didn't work out for me in the end but i guess this would be just a bit to complex at this time for me and I'll better try some easier solutions.
To Thomas Schindl: I wanted my parts to register themselves in a Singleton, so that they could communicate which each other (I am quite sure that there is a better way to do this, but it worked quite well for me this way). Problem now is that I have to be very careful what I check and call at which time, cause it is possible that one part hasn't registered itself yet.
[Updated on: Sat, 08 December 2012 13:17] Report message to a moderator
FUDForum. Page generated in 0.04122 seconds
