Can I divide my script in different files? [message #988836] |
Mon, 03 December 2012 11:55 |
Hello!
I've just moved from mediniQVT to ATL, and I'm really happy with the performance and understandability of the code.
There is one simple thing that I miss from "programming" let's say, to modularize my files. I've checked the documentation and the forum with no luck.
I'd like to divide my ATL file in different parts, just for a matter of prolixity.
Libraries are not the solution because I only can put helpers in them, and I'd like also to include rules.
is it possible?
thank you in advance!
Re: Can I divide my script in different files? [message #989006 is a reply to message #988841] |
Tue, 04 December 2012 09:47 |
Hey! thank you!
At the begining I thought that it couldn't work because of the common lazy rules that I call from different parts of the code, I mean, from the two files considering the division... but it seems that the syntax checker don't check the referenced methods (lazy rules or called rules), is that right?
I've already done the change, and it's working
thank you!
FUDForum. Page generated in 0.02565 seconds
