Re: [CDO] Transaction commit & Threads [message #988971 is a reply to message #988811] |
Tue, 04 December 2012 06:28 |
Am 03.12.2012 11:19, schrieb Martin Bl:
> hi,
> i found some exceptions in my application log -
> org.eclipse.emf.cdo.util.CommitException: java.lang.OutOfMemoryError: unable to create new native thread
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1148)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1154)
> at mypack.MyClass.commit(MyClass.java:357)
> ... 26 more
> Caused by: java.lang.OutOfMemoryError: unable to create new native thread
> at java.lang.Thread.start0(Native Method)
> at java.lang.Thread.start(Unknown Source)
> at org.eclipse.net4j.util.concurrent.Worker.doActivate(Worker.java:96)
> at org.eclipse.net4j.util.concurrent.QueueWorker.doActivate(QueueWorker.java:109)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:76)
> at org.eclipse.emf.internal.cdo.view.CDOViewImpl.getInvalidationRunner(CDOViewImpl.java:852)
> at org.eclipse.emf.internal.cdo.view.CDOViewImpl.invalidate(CDOViewImpl.java:794)
> at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.invalidateView(CDOSessionImpl.java:1170)
> at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.invalidateOrdered(CDOSessionImpl.java:1152)
> at org.eclipse.emf.internal.cdo.session.CDOSessionImpl.invalidate(CDOSessionImpl.java:1109)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl$CDOCommitContextImpl.postCommit(CDOTransactionImpl.java:2809)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:74)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1134)
> at first glance a memory leak in my application - but what makes me suspicious is, that it happens only on cdo
> transaction commits ...
> after the failed commit everything works as expected again (commits also) until it happens again a few hours or days
> later.
> (its a vaadin-webapp running within apache tomcat on a windows server)
> any ideas?
Not really without more infos. Is it possible that you capture a list of the active threads when this happens?
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Transaction commit & Threads [message #989243 is a reply to message #988971] |
Wed, 05 December 2012 10:39 |
Martin Blühweis Messages: 11 Registered: February 2012 Location: Innsbruck, Austria |
Eike Stepper wrote on Tue, 04 December 2012 07:28Not really without more infos. Is it possible that you capture a list of the active threads when this happens?
btw. i'm working with 4.1.0
i added the threads to my logs and got interesting results.
after starting my application i always edit the same field of the same entity and commit my transaction.
after the 1st commit i get 17 "InvalidationRunner-View ${count}" - threads
2nd: 34 (+17)
3rd: 52 (+18)
4th: 71 (+19)
5th: 91 (+20)
6th: 112 (+21)
the number of "pool-1-thread-${count2}" threads is increased by 1 with every commit.
all other threads seem to be constantly - i compared names and counts.
hope this helps,
cheers,
martin
[Updated on: Wed, 05 December 2012 10:40] Report message to a moderator
Re: [CDO] Transaction commit & Threads [message #989453 is a reply to message #989436] |
Thu, 06 December 2012 09:47 |
Am 06.12.2012 09:56, schrieb Martin Bl:
> Eike Stepper wrote on Thu, 06 December 2012 08:20
>> Is it possible that you open a new CDOTransaction for each commit? Why is that?
>> And if so, is t possible that you don't close() it properly?
> no.
> every user gets exactly 1 transaction, which is closed when he closes the browser (tab).
That sounds ok.
> so i extend my logging and repeat my tests:
Sorry, the below is really not readable in my news client ;-(
> INFO 12-06 09:28:59 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:28:59 Running
> threads: 65 (EhsCdoResource.java:385) INFO 12-06 09:28:59 Running invalidation threads: 24
> (EhsCdoResource.java:386) INFO 12-06 09:28:59 Difference: 41 (EhsCdoResource.java:387) INFO 12-06
> 09:29:16 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:29:16 Running
> threads: 90 (EhsCdoResource.java:385) INFO 12-06 09:29:16 Running invalidation threads: 48
> (EhsCdoResource.java:386) INFO 12-06 09:29:16 Difference: 42 (EhsCdoResource.java:387) INFO 12-06
> 09:29:37 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:29:37 Running
> threads: 116 (EhsCdoResource.java:385) INFO 12-06 09:29:37 Running invalidation threads: 73
> (EhsCdoResource.java:386) INFO 12-06 09:29:37 Difference: 43 (EhsCdoResource.java:387) INFO 12-06
> 09:29:52 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:29:53 Running
> threads: 143 (EhsCdoResource.java:385) INFO 12-06 09:29:53 Running invalidation threads: 99
> (EhsCdoResource.java:386) INFO 12-06 09:29:53 Difference: 44 (EhsCdoResource.java:387) INFO 12-06
> 09:30:08 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:30:08 Running
> threads: 171 (EhsCdoResource.java:385) INFO 12-06 09:30:08 Running invalidation threads: 126
> (EhsCdoResource.java:386) INFO 12-06 09:30:08 Difference: 45 (EhsCdoResource.java:387) INFO 12-06
> 09:30:15 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:30:15 Running
> threads: 199 (EhsCdoResource.java:385) INFO 12-06 09:30:15 Running invalidation threads: 154
> (EhsCdoResource.java:386) INFO 12-06 09:30:15 Difference: 45 (EhsCdoResource.java:387)
> now i close my browser tab ...
> INFO 12-06 09:34:26 closing Transaction 1 from Session2 [MARTIN] (EhsCdoResource.java:662) (the session was closed too)
> .. and open a new one to change and commit some data:
> INFO 12-06 09:37:01 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:37:02 Running
> threads: 75 (EhsCdoResource.java:385) INFO 12-06 09:37:02 Running invalidation threads: 30
> (EhsCdoResource.java:386) INFO 12-06 09:37:02 Difference: 45 (EhsCdoResource.java:387) INFO 12-06
> 09:37:20 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:37:20 Running
> threads: 105 (EhsCdoResource.java:385) INFO 12-06 09:37:20 Running invalidation threads: 60
> (EhsCdoResource.java:386) INFO 12-06 09:37:20 Difference: 45 (EhsCdoResource.java:387) INFO 12-06
> 09:37:32 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:37:32 Running
> threads: 136 (EhsCdoResource.java:385) INFO 12-06 09:37:32 Running invalidation threads: 91
> (EhsCdoResource.java:386) INFO 12-06 09:37:32 Difference: 45 (EhsCdoResource.java:387) INFO 12-06
> 09:37:37 try to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:37:37 Running
> threads: 168 (EhsCdoResource.java:385) INFO 12-06 09:37:37 Running invalidation threads: 123
> (EhsCdoResource.java:386) INFO 12-06 09:37:37 Difference: 45 (EhsCdoResource.java:387)
> now a close the tab once more to do the same again:
> INFO 12-06 09:41:45 closing Transaction 1 from Session3 [MARTIN] (EhsCdoResource.java:662) INFO 12-06 09:43:10 try
> to commit transaction Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:43:10 Running threads: 79
> (EhsCdoResource.java:385) INFO 12-06 09:43:10 Running invalidation threads: 34 (EhsCdoResource.java:386) INFO 12-06
> 09:43:10 Difference: 45 (EhsCdoResource.java:387) INFO 12-06 09:43:26 try to commit transaction
> Transaction 1 (EhsCdoResource.java:359) INFO 12-06 09:43:26 Running threads: 113
> (EhsCdoResource.java:385) INFO 12-06 09:43:26 Running invalidation threads: 68 (EhsCdoResource.java:386) INFO 12-06
> 09:43:26 Difference: 45 (EhsCdoResource.java:387)
> as you can see, the number of invalidation threads is increasing and increasing. closing transaction and session stops
> many threads, but not all of them.
> so the outofmemory exceptions seems to be unavoidable after a while.
Is it possible that you set a breakpoint in CDOViewImpl.doDeactivate() and try to find out what this code does for you:
protected void doDeactivate() throws Exception
CDOViewRegistryImpl.INSTANCE.deregister(this);
if (invalidationRunner != null)
LifecycleUtil.deactivate(invalidationRunner, OMLogger.Level.WARN);
invalidationRunner = null;
> maybe it would be better to use 1 session for all my users - what do you think?
Yeah, that would save a lot of the heap space! The session with the revision cache is probably the most expensive client
facility. But note that currently the user information (if used at all) is bound to the session. By reusing the session
all transactions would persist that userID (if used). This could probably be made more flexible with a feature request.
Cheers
/Eike
Cheers
/Eike
Re: [CDO] Transaction commit & Threads [message #989520 is a reply to message #989455] |
Thu, 06 December 2012 15:29 |
thank you eike for guiding me in the right direction
after debugging for a while i could find the problem, i'll try to describe:
i modified my code as suggested to have just 1 session for all users. was done quickly and worked well, but i was surprised when i repeated my tests.
after the first application session (which does not mean cdosession) transaction #1 was closed, after the 2nd something like transaction #30.
but by debugging into the code i found out, that no unexpected transactions were created meanwhile, just one for the new application session.
but what my app did, was creating views (to show, which user created data at which date) ... and yes, these views were not closed ... (in this case i was relieing on the GC)
so i'll fix that, and also think about your proposal to use one view for all users and starting a transaction when needed.
thanks a lot,
martin
FUDForum. Page generated in 0.03432 seconds
