Re: Texo - orm annotation model has invalid default values [message #988807 is a reply to message #988771] |
Mon, 03 December 2012 09:55 |
Hi Pradeep,
Thanks for noting, it was an error in the orm.xsd from eclipselink. I solved this and published a new build with the fix.
gr. Martin
On 12/03/2012 05:56 AM, Pradeep Badiger wrote:
> I tried to add @Column to a field and i saw that the default values for nullable,insertable,updatable are set to false. Whereas these values have to be true by default as per the @Column documentation.
> http://www.oracle.com/technetwork/middleware/ias/toplink-jpa-annotations-096251.html#Column
> orm-annotation @Column properties in ide
> thanks,
> Pradeep V.B.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03763 seconds
