Re: A new version of tutorial [message #988700 is a reply to message #988581] |
Sat, 01 December 2012 14:33 |
Ed Willink Messages: 7655 Registered: July 2009 |
I'm not a Papyrus committer, but good quality contributions are
generally encouraged. We are all too busy to do everything ourselves.
Eclipse IP processes require traceability of authorship and this is
eased by forking the relevant Papyrus GIT through its GitHub mirror.
I recommend creating your own public GitHub fork and making the changes
there. Raise a Bugzilla identifying what you are doing. When ready a
Papyrus committer can then pull your changes into the main Papyrus repo.
Ed Willink
On 30/11/2012 15:26, Mary P. wrote:
> Hello!
> Can I provide a modified version of "Papyrus Tutorial: How to create a
> new Papyrus UML Diagram" adapted to Eclipse Juno to the Eclipse
> Community?
> The old version
> (http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/trunk/examples/others/org.eclipse.papyrus.example.diagram.simplediagram/docs/PapyrusDevelopperTutorial_OnDiagramCreating.odt)
> is based on Eclipse MT Helios
> As you know, I asked a lot of questions when I tried to complete the
> Tutorial using Eclipse Juno. Eventually I managed to complete it and I
> found out quite a lot of modifications (like the names of packages,
> modifications of plugin.xml file, etc) and some steps that were a bit
> unclear for me (for the very beginner:)). Maybe some of this
> information could be useful for other people!
> So, if you let me provide a modified version of Tutorial, that would
> be really great! And if it is possible, I would like to know, what
> should be the procedure and whom can I send the modified version for
> revision?
> Thanks in advance!
> Best regards,
> Mary
Re: A new version of tutorial [message #988702 is a reply to message #988700] |
Sat, 01 December 2012 15:25 |
Apologies. I assumed that Papyrus was in GIT, when I should have known
better.
For SVN, you'll need to develop the change, then attach a patch to the
Bugzilla.
Ed Willink
On 01/12/2012 14:33, Ed Willink wrote:
> Hi
> changes there. Raise a Bugzilla identifying what you are doing. When
> ready a Papyrus committer can then pull your changes into the main
> Papyrus repo.
> Regards
> Ed Willink
>> Hello!
>> a new Papyrus UML Diagram" adapted to Eclipse Juno to the Eclipse
>> Community?
>> The old version
>> I found out quite a lot of modifications (like the names of packages,
>> revision?
>> Thanks in advance!
>> Best regards,
>> Mary
FUDForum. Page generated in 0.03436 seconds
