how to access to association end in code [message #988537] |
Fri, 30 November 2012 11:58 |
Abbas Mansoori Razi Messages: 7 Registered: August 2012 |
I use a model with two class diagram.
but I give a error that "not recognized variable referee" for
self.referee->forAll(r| not r.isStudent).
model is attached and a section of my code is:
OCL<?, EClassifier, EOperation, EStructuralFeature, EEnumLiteral, EParameter, ?, CallOperationAction, ?, Constraint, EClass, EObject> ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier,?, ?, Constraint> helper = ocl.createOCLHelper();
//start PAPER classfier
// set the OCL context classifier for PAPER--------------------
helper.setContext(PaperresearcherrosemodelPackage.Literals.PAPER);
// create an extent map for 'submission'
Map<EClass, Set<? extends EObject>> extents = new HashMap<EClass, Set<? extends EObject>>();
Set<Paper> submission = new HashSet<Paper>();
extents.put(PaperresearcherrosemodelPackage.Literals.PAPER, submission);
// tell the OCL environment what our classifier extents are
ocl.setExtentMap(extents);
Paper paper = PaperresearcherrosemodelFactory.eINSTANCE.createPaper();
paper.setTitle("uml-ocl verification");
paper.setWordCount(5000);
paper.setStudentPaper(true);
submission.add(paper);
// create an extent map for 'manuscript'
Set<Paper> manuscript = new HashSet<Paper>();
extents.put(PaperresearcherrosemodelPackage.Literals.PAPER, manuscript);
manuscript.add(paper);
//end PAPER classfier **************************************
//start RESEARCHER classfier *********************************************
Set<Researcher> referee = new HashSet<Researcher>();
extents.put(PaperresearcherrosemodelPackage.Literals.RESEARCHER, referee);
Researcher researcher = aperresearcherrosemodelFactory.eINSTANCE.createResearcher();
researcher.setName("reza");
researcher.setIsStudent(false);
referee.add(researcher);
Set<Researcher> author = new HashSet<Researcher>();
extents.put(PaperresearcherrosemodelPackage.Literals.RESEARCHER,author);
author.add(researcher);
//end RESEARCHER classfier
//new project is started in date 1391/08/27------------------------------------
try {
query= helper.createQuery("self.referee->forAll(r| not r.isStudent)");
} catch (ParserException e) {
e.printStackTrace();
Attachment: model.JPG
(Size: 16.75KB, Downloaded 227 times)
Re: how to access to association end in code [message #988680 is a reply to message #988537] |
Sat, 01 December 2012 07:33 |
Ed Willink Messages: 7655 Registered: July 2009 |
If you understand you're problem well enough to present only a part of
it, you are surely able to solve the problem yourself.
I see no question in your report and no error message either, so it is
far from clear to me what you want to know.
I can only guess that you have neglected to realize that EMF reifies
model properties with getters and setters, so getXXXX.
If you want help ZIP up a simple project that demonstrates your best
endeavours at solving a clearly expressed problem.
Ed Willink
> try {
FUDForum. Page generated in 0.03024 seconds
