ModelingAssistant Popup for ShapeCompartments [message #988175] |
Wed, 28 November 2012 18:28 |
Daniel König Messages: 24 Registered: November 2012 |
Hello!
I had to change my compartments to ShapeCompartments (ListLayout = false).
Since I changed this I do not get the ModelingAssistant Popup anymore.
The EditPolicy should be installed by default:
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeCompartmentEditPart:
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
installEditPolicy(EditPolicyRoles.CREATION_ROLE,
new CreationEditPolicy());
installEditPolicy(EditPolicy.LAYOUT_ROLE, new XYLayoutEditPolicy());
installEditPolicy(EditPolicy.CONTAINER_ROLE, new ContainerEditPolicy());
// TODO: this edit policy get overriden by code at the end of this
// function
// may be this breaks some use cases; it needs to be checked
installEditPolicy(EditPolicyRoles.DRAG_DROP_ROLE,
new DiagramLinkDragDropEditPolicy());
installEditPolicy(EditPolicy.GRAPHICAL_NODE_ROLE,
new ContainerNodeEditPolicy());
// Install an edit policy for snap
installEditPolicy(EditPolicyRoles.SNAP_FEEDBACK_ROLE,
new SnapFeedbackPolicy());
new ShapeCompartmentDropEditPolicy());
installEditPolicy(EditPolicyRoles.POPUPBAR_ROLE,
new PopupBarEditPolicy());
ComponentStateCompartmentEditPart extends ShapeCompartmentEditPart:
installEditPolicy(EditPolicyRoles.SEMANTIC_ROLE, new ComponentComponentStateCompartmentItemSemanticEditPolicy());
installEditPolicy(EditPolicyRoles.CREATION_ROLE, new CreationEditPolicyWithCustomReparent(
MachineVisualIDRegistry.TYPED_INSTANCE));
installEditPolicy(EditPolicyRoles.CANONICAL_ROLE, new ComponentComponentStateCompartmentCanonicalEditPolicy());
The ModelingAssistantProvider should also be fine:
public List getTypesForPopupBar(IAdaptable host) {
IGraphicalEditPart editPart = (IGraphicalEditPart) host.getAdapter(IGraphicalEditPart.class);
if (editPart instanceof ModelEditPart) {
ArrayList<IElementType> types = new ArrayList<IElementType>(1);
types.add(MachineElementTypes.Machine_2001);
return types;
if (editPart instanceof MachineEditPart) {
types.add(MachineElementTypes.Component_3001);
return types;
if (editPart instanceof ComponentStateCompartmentEditPart) {
types.add(MachineElementTypes.State_3002);
return types;
if (editPart instanceof StateComponentValueCompartmentEditPart) {
types.add(MachineElementTypes.StateValue_3004);
return types;
return Collections.EMPTY_LIST;
Is there any way I can get the ModelingAssistant back for my ShapeCompartment?
I recognized in the ModelingAssistantProvider that the EditPart for ListCompartments is the Node itself (for example "MachineEditPart"). If it's a ShapeCompartment, the CompartmentEditPart is used ("ComponentStateCompartmentEditPart" resp. "StateComponentValueCompartmentEditPart").
Manually changing to the Node which contains the Compartment did not have any effect.
I hope someone can help me.
Thank you!
Re: ModelingAssistant Popup for ShapeCompartments [message #1183997 is a reply to message #1183014] |
Wed, 13 November 2013 06:39 |
serhat gezgin Messages: 243 Registered: January 2013 Location: Izmir |
yes i check the org.eclipse.gmf.runtime.emf.ui.modelingAssistantProviders extension
<extension point="org.eclipse.gmf.runtime.emf.ui.modelingAssistantProviders" id="modelassist-provider">
<?gmfgen generated="true"?>
<modelingAssistantProvider class="com.mdd4cca.msf.content.diagram.providers.ContentModelingAssistantProvider">
<Priority name="Lowest"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ContentModelEditPart" id="ContentModel_1000"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.WebEditPart" id="Web_2001"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.EntityModelEditPart" id="EntityModel_2003"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.DataBaseEditPart" id="DataBase_2002"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.CustomListEditPart" id="CustomList_3001"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ContentTypeEditPart" id="ContentType_3002"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.OverrideFieldEditPart" id="OverrideField_3020"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.TextFieldEditPart" id="TextField_3003"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.NumberFieldEditPart" id="NumberField_3004"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.BooleanFieldEditPart" id="BooleanField_3005"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.UserFieldEditPart" id="UserField_3006"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.CurrencyFieldEditPart" id="CurrencyField_3007"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.URLFieldEditPart" id="URLField_3008"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.NoteFieldEditPart" id="NoteField_3009"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.DateTimeFieldEditPart" id="DateTimeField_3010"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ChoiceFieldEditPart" id="ChoiceField_3011"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ViewEditPart" id="View_3012"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ViewFieldEditPart" id="ViewField_3013"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.Web2EditPart" id="Web_3014"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.EnumTypeEditPart" id="EnumType_3024"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.LiteralEditPart" id="Literal_3025"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ComplexTypeEditPart" id="ComplexType_3026"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ScalarProperty2EditPart" id="ScalarProperty_3028"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ComplexProperty2EditPart" id="ComplexProperty_3029"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.EntityEditPart" id="Entity_3021"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ScalarPropertyEditPart" id="ScalarProperty_3030"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ComplexPropertyEditPart" id="ComplexProperty_3031"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.NavigationPropertyEditPart" id="NavigationProperty_3032"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.TableEditPart" id="Table_3015"/>
<object class="com.mdd4cca.msf.content.diagram.edit.parts.ColumnEditPart" id="Column_3018"/>
<context elements="ContentModel_1000,Web_2001,EntityModel_2003,DataBase_2002,CustomList_3001,ContentType_3002,OverrideField_3020,TextField_3003,NumberField_3004,BooleanField_3005,UserField_3006,CurrencyField_3007,URLField_3008,NoteField_3009,DateTimeField_3010,ChoiceField_3011,View_3012,ViewField_3013,Web_3014,EnumType_3024,Literal_3025,ComplexType_3026,ScalarProperty_3028,ComplexProperty_3029,Entity_3021,ScalarProperty_3030,ComplexProperty_3031,NavigationProperty_3032,Table_3015,Column_3018"/>
</modelingAssistantProvider>
</extension>
FUDForum. Page generated in 0.05035 seconds
