Home » Modeling » GMF (Graphical Modeling Framework) » On Save Action
On Save Action [message #987761] Tue, 27 November 2012 18:11 Go to next message
I'm generating code from my diagram and I'd like to run the generation workflow whenever the diagram is saved. What's the appropriate way to do this? I assume I should add some code to whatever runs the save but I'm not sure where this is, or even if that's the appropriate way.
thanks,
Nick
[Updated on: Tue, 27 November 2012 18:11] by Moderator
Re: On Save Action [message #987799 is a reply to message #987761] Wed, 28 November 2012 03:46 Go to previous message
in you xxxDiagramEditor you can override doSave(IProgressMonitor progressMonitor) this will do the jog. If you generation takes a lot of resources you could do it when Eclipse does an automatic build.
Ralph
Previous Topic:Canvas and Top node customization
Next Topic:Custom ModelAssistant Popup Names and Icons
Current Time: Fri Nov 07 11:42:06 EST 2025
Powered by FUDForum. Page generated in 0.03668 seconds
