making birtviewer 3.7.1 compatible for IE9 [message #987722] |
Tue, 27 November 2012 18:09 |
birt user Messages: 11 Registered: August 2012 |
I have JAVA webapp running on Jetty and I am using BIRT for adhoc reporting. I am using the BIRT taglib in the webapp to make a webservice request to server that is running BIRT webviewer. The app and reports run fine on FF, Chrome and Safari, but IE9 fails.
I have looked at similar issues in BIRT forum where it is suggested that birtviewer only works with IE7 and the only way is to use the compatibility mode of IE9. Unfortunately that is not a solution for me. My requirement is t make the reports render on IE9. This issue is quite old and I am sure there would now be way to support IE9. Any help would be appreciated
BTW I am using frameset and prototype.js version is 1.4.0
thanks
birt user
[Updated on: Tue, 27 November 2012 18:13] Report message to a moderator
Re: making birtviewer 3.7.1 compatible for IE9 [message #988957 is a reply to message #988561] |
Tue, 04 December 2012 04:48 |
So, the workaround suggested doesn't work for you, either? If not, I'd vote on the bug. You might also post in the bug to let them know you're seeing the issue too. The more votes for a bug, the more priority it will get.
Michael
Developer Evangelist, Silanis
FUDForum. Page generated in 0.03010 seconds
