Home » Eclipse Projects » Remote Application Platform (RAP) » Getting Started(HTTP ERROR: 404 Problem accessing /rap. Reason: ProxyServlet: /rap -------------------------------------------------------------------------------- Powered by Jetty://)
Getting Started [message #987543] Tue, 27 November 2012 05:28 Go to next message
Bindhu Niranjan is currently offline Bindhu NiranjanFriend
I am a beginner and getting started to use eclipse RAP.
I installed eclipse RAP and I tried executing the first sample hello RAP template.
I get this error message,
HTTP ERROR: 404
ProxyServlet: /rap
Powered by Jetty://
Can any one please help me get started?
Re: Getting Started [message #987570 is a reply to message #987543] Tue, 27 November 2012 08:22 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
welcome to the RAP community. This happens when browser is opened before
the server is completely started. Just press the reload button and your
application will appear.
Best,
Ivan
On 11/27/2012 7:28 AM, Bindhu Niranjan wrote:
> RAP template.
> HTTP ERROR: 404
> ProxyServlet: /rap
> Powered by Jetty://
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Getting Started [message #987640 is a reply to message #987570] Tue, 27 November 2012 12:05 Go to previous messageGo to next message
Hi Ivan,
Thank you for your response.
I still keep getting the same message in the browser.
I also see the below listed error message in the console.
2012-11-27 15:58:24.636:INFO:oejs.Server:jetty-8.1.3.v20120522
2012-11-27 15:58:24.759:INFO:oejs.AbstractConnector:Started SelectChannelConnector@0.0.0.0:4153
!SESSION 2012-11-27 15:58:23.980 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -dev file:C:/Users/Fusionss-1/workspace_juno/.metadata/.plugins/org.eclipse.pde.core/test/dev.properties -os win32 -ws win32 -arch x86_64 -console -consolelog -data C:\Users\Fusionss-1\workspace_juno/.metadata/.plugins/org.eclipse.rap.ui.launch/test
!ENTRY org.eclipse.osgi 4 0 2012-11-27 15:58:25.144
!MESSAGE An unexpected runtime error has occurred.
!STACK 0
java.lang.NullPointerException: The parameter 'path' must not be null.
at org.eclipse.rap.rwt.internal.util.ParamCheck.notNull(ParamCheck.java:40)
at org.eclipse.rap.rwt.internal.application.ApplicationImpl.addEntryPoint(ApplicationImpl.java:93)
at org.eclipse.rap.ui.internal.servlet.WorkbenchApplicationConfigurator.registerApplicationEntryPoints(WorkbenchApplicationConfigurator.java:205)
at org.eclipse.rap.ui.internal.servlet.WorkbenchApplicationConfigurator.configure(WorkbenchApplicationConfigurator.java:101)
at org.eclipse.rap.rwt.internal.application.ApplicationContextConfigurator.configureCustomSettings(ApplicationContextConfigurator.java:51)
at org.eclipse.rap.rwt.internal.application.ApplicationContextConfigurator.configure(ApplicationContextConfigurator.java:40)
at org.eclipse.rap.rwt.internal.application.ApplicationContext.doActivate(ApplicationContext.java:249)
at org.eclipse.rap.rwt.internal.application.ApplicationContext.activate(ApplicationContext.java:120)
at org.eclipse.rap.rwt.application.ApplicationRunner.activateApplicationContext(ApplicationRunner.java:114)
at org.eclipse.rap.rwt.application.ApplicationRunner.start(ApplicationRunner.java:82)
at org.eclipse.rap.rwt.osgi.internal.ApplicationReferenceImpl.startRWTApplication(ApplicationReferenceImpl.java:77)
at org.eclipse.rap.rwt.osgi.internal.ApplicationReferenceImpl.start(ApplicationReferenceImpl.java:63)
at org.eclipse.rap.rwt.osgi.internal.ApplicationLauncherImpl.doLaunch(ApplicationLauncherImpl.java:103)
at org.eclipse.rap.rwt.osgi.internal.ApplicationLauncherImpl.launch(ApplicationLauncherImpl.java:85)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.startApplication(HttpServiceTracker.java:75)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.addingService(HttpServiceTracker.java:46)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.addingService(HttpServiceTracker.java:1)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:317)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker.access$6(HttpServiceTracker.java:1)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker$ApplicationLauncherTracker.addingService(HttpServiceTracker.java:125)
at org.eclipse.rap.ui.internal.servlet.HttpServiceTracker$ApplicationLauncherTracker.addingService(HttpServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:894)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451)
at org.eclipse.rap.rwt.osgi.internal.Activator.registerService(Activator.java:50)
at org.eclipse.rap.rwt.osgi.internal.Activator.registerApplicationLauncher(Activator.java:45)
at org.eclipse.rap.rwt.osgi.internal.Activator.start(Activator.java:26)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.rap.ui.workbench 4 0 2012-11-27 15:58:25.146
!MESSAGE FrameworkEvent ERROR
!STACK 0
osgi>
Please advice.
Re: Getting Started [message #987645 is a reply to message #987640] Tue, 27 November 2012 12:21 Go to previous message
probably you are using RAP 2.0M3 with Juno "Eclipse for RCP and RAP
developers" which includes RAP Tools 1.5.x. The application generated
with templates by RAP Tools 1.5.x is not compatible with RAP 2.0. If you
are using RAP Tools 1.5 I will suggest to stay with RAP Runtime 1.5. If
you want to go with RAP 2.0 please get Eclipse Juno Classic package and
install RAP Tools 2.0 from [1].
[1] http://www.eclipse.org/rap/downloads/
HTH,
Ivan
On 11/27/2012 2:06 PM, Bindhu Niranjan wrote:
> Hi Ivan,
> mailto:SelectChannelConnector@0.0.0.0:4153
> java.version=1.7.0
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
> Please advice.
Ivan Furnadjiev
Previous Topic:How is Apress RAP book up-to-date/outdated?
Next Topic:Trigger UI update with javascript
Current Time: Tue Apr 16 15:59:37 GMT 2024
Powered by FUDForum. Page generated in 0.59283 seconds
