Re: Teneo EMF @OneToOne and @ManyToOne [message #987259 is a reply to message #987233] |
Sun, 25 November 2012 09:47 |
Hi Svetoslav,
It seems that you set the OneToOne/ManyToOne annotations are set on an EAttribute and not on an EReference.
If that's not the case can you post/send the ecore?
gr. Martin
On 11/24/2012 08:59 PM, Svetoslav Mising name wrote:
> Hello.
> I am using Teneo 2.0.1 and Hibernate 4.1.8. Here are my DataStore init options:
> props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "true"); props.setProperty(PersistenceOptions.ID_COLUMN_NAME,
> "id");
> props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_KEY, "true");
> props.setProperty(PersistenceOptions.FETCH_CONTAINMENT_EAGERLY, "false");
> props.setProperty(PersistenceOptions.FETCH_ASSOCIATION_EXTRA_LAZY, "true");
> I'd like to use fetch=EAGER for some references in my objects. I use these annotations in ecore model:
> @OneToOne(fetch=EAGER) ; @ManyToOne(fetch=EAGER) ;
> <eAnnotations source="teneo.jpa">
> <details key="value" value="@OneToOne(fetch=EAGER)"/>
> </eAnnotations>
> <details key="value" value="@ManyToOne(fetch=EAGER)"/>
> </eAnnotations>
> I get the following exception:
> org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The eclass: HbAnnotatedEAttribute does not have an
> efeature for OneToOne
> How can I achieve loading of the needed object references?
> Cheers,
> Svetoslav
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Teneo EMF @OneToOne and @ManyToOne [message #987523 is a reply to message #987504] |
Mon, 26 November 2012 23:25 |
Hi Svetoslav,
I guess student references university, not sure why the extra joins happen, it all depends on the select behavior of
hibernate which can be influenced:
http://docs.jboss.org/hibernate/orm/4.1/manual/en-US/html_single/#performance-fetching
I would need to see the complete model or better the generated hbm to comment on this in more detail.
gr. Martin
On 11/26/2012 11:10 PM, Svetoslav Mising name wrote:
> Yes, you are right. I was using the greatest design pattern - copy/paste and accidentally copied @OneToOne under an
> attribute :) . Thank you.
> I'd like to ask one more question though (not sure if I have to open a new topic). After I switched to
> FETCH_ASSOCIATION_EXTRA_LAZY = "true" and FORCE_LAZY = "true" hibernate generates very wrong queries - on selects it
> joins completely irrelevant tables: for example I try to get Student with id = 1 but it joins University table as well
> (University has many Students but it is irrelevant to this query - the HQL looks like: select s from Student s where
> s.id=1).
> Cheers,
> Svetoslav
The Netherlands
FUDForum. Page generated in 0.03577 seconds
