Home » Newcomers » Newcomers » new to java. pls help me(hello friends i am new to java but determined to learn it . So can anyone pls suggest from where do i start i mean any good books or tutorials and also which version of eclipse wud be good for a begin)
new to java. pls help me [message #986989] Thu, 22 November 2012 17:25 Go to next message
dark knight is currently offline dark knightFriend
hello friends i am new to java but determined to learn it . So can anyone pls suggest from where do i start i mean any good books or tutorials and also which version of eclipse wud be good for a beginer like me. Your suggestions will be valued near to my heart . thank you Smile
Re: new to java. pls help me [message #987135 is a reply to message #986989] Fri, 23 November 2012 17:36 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> like me. Your suggestions will be valued near to my heart . thank you :)
I would suggest...
Choose between Eclipse and NetBeans. NetBeans seemed simpler to me 5
years ago, the last time I looked at it. I say this in all honesty,
however, actual large-scale and commercial applications are developed
using Eclipse and not NetBeans (so much).
Assuming you choose Eclipse, ...
1. Just about any version starting with Galileo is fine, but I'd suggest
at least a version as recent as Helios.
2. Use http://www.vogella.com/eclipseide.html for its first three tutorials.
3. Read Head First Java from O'Reilly and do the example in one or more
Eclipse projects.
4. Come back here when you get stuck on Eclipse issues.
5. Go to javaranch.com or stackoverflow.com when you get stuck on Java
questions.
For help installing Eclipse, I suggest this forum. I also suggest the
first two steps in the following summary:
http://www.javahotchocolate.com/tutorials/eclipse-summary.html
You're in good hands here.
Best of luck to you.
Russ
Re: new to java. pls help me [message #987142 is a reply to message #987135] Fri, 23 November 2012 18:50 Go to previous messageGo to next message
Dear Russel ,
Thanks a lot for ur guidance i am sure i am in bright side to learn java. And seriously i had not expected so much support for a newcomer .. Kudos sir. Thanks a lot. I will be in touch as soon as i get doubts .
Re: new to java. pls help me [message #987166 is a reply to message #986989] Fri, 23 November 2012 22:37 Go to previous messageGo to next message
Andrew Gies is currently offline Andrew GiesFriend
google eclipse tutorial sourceforge, the first result is an amazing resource... On of the best getting started(s?) around... (sorry i couldn't post the link, i need to have more posts to be able to do that.)
andrewgies17 Very Happy
andrewgies17
Re: new to java. pls help me [message #987429 is a reply to message #987166] Mon, 26 November 2012 15:08 Go to previous messageGo to next message
dear andrew ,
i will surely go through the tutorials . thanks a lot. that will surely help me a lot Smile pls stay in touch with ur valuable posts
thank you .
Re: new to java. pls help me [message #987435 is a reply to message #987429] Mon, 26 November 2012 15:31 Go to previous messageGo to next message
I think that the eclipse and java for total beginners (I know, a mouthful) is the best out of those. It's a download of 16, 10(ish) minute long videos, the first of which you can watch online. You do however need flash player, but one more download is worth it. When you're ready to move on from that, add to this post and i'll try to get you more tutorials. Very Happy
andrewgies17
Re: new to java. pls help me [message #987436 is a reply to message #987435] Mon, 26 November 2012 15:33 Go to previous messageGo to next message
Ok, I just gained the ability to post links, here you go! http://eclipsetutorial.sourceforge.net/totalbeginner.html
Some things are left out of the video, so make sure to use the companion document, a list of valuable terms and definitions is toward the back of the document. Smile
andrewgies17
[Updated on: Mon, 26 November 2012 15:38]
Report message to a moderator
Re: new to java. pls help me [message #987440 is a reply to message #987436] Mon, 26 November 2012 15:54 Go to previous messageGo to next message
No, this isn't so good. It's based on Europa (2007). Many tutorials
elsewhere use modern Eclipse, in particular, the ones from vogella.de.
Re: new to java. pls help me [message #987508 is a reply to message #987440] Mon, 26 November 2012 22:30 Go to previous messageGo to next message
Well I have been through all of them, they are identical.
andrewgies17
Re: new to java. pls help me [message #987510 is a reply to message #987508] Mon, 26 November 2012 22:32 Go to previous message
That's good to know!
Previous Topic:Cannot get Internal Browser to work using webkit - [Eclipse 3.7.2 - Ubuntu 11.10]
Next Topic:Hello World problem
Current Time: Tue May 11 20:55:30 GMT 2021
Powered by FUDForum. Page generated in 0.02455 seconds
