Home » Archived » BIRT » Your Feedback Is Needed To Plan the Next Eclipse BIRT Release(Your Opinion Counts!)
Your Feedback Is Needed To Plan the Next Eclipse BIRT Release [message #986845] Wed, 21 November 2012 22:15 Go to next message
Mihail Mihaylov is currently offline Mihail MihaylovFriend
Feedback from users is one of the key inputs into the BIRT planning process. Make your voice heard in two simple steps:
1) Complete the 2012 BIRT survey. By filling out the survey, you provide us with valuable information on how you use BIRT and how you would like to see BIRT evolve. Survey should take less than 3 minutes of your time. To start click the survey link above.
2) Vote for the BIRT enhancements you need. With BIRT 4.2 behind us we are busily planning the Kepler release. To help us identify the BIRT enhancements important to you, we encourage you to use the Bugzilla Vote feature. It allows you to vote for up to ten enhancements. To cast your vote, locate the corresponding Bugzilla BIRT entry or create a new one as needed and then click on the "(vote)" link that appears on the right of the "Importance" field.
Thank You,
Mihail Mihaylov
Product Manager for BIRT
Re: Your Feedback Is Needed To Plan the Next Eclipse BIRT Release [message #987516 is a reply to message #986845] Mon, 26 November 2012 22:56 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
It is important to vote as we on the PMC are in the process of setting priorities on what functionality will be added to BIRT first. So please vote.
Jason
Previous Topic:Help: Date as column name
Next Topic:Exception generated when working with a Joint Data Set with Scripted Data Sources and Java Classes
Current Time: Thu Mar 23 03:01:59 GMT 2023
Powered by FUDForum. Page generated in 0.01508 seconds
