Home » Eclipse Projects » Virgo » Spring framework 3.2.0.RC1 available for testing with Virgo
Spring framework 3.2.0.RC1 available for testing with Virgo [message #986773] Wed, 21 November 2012 15:22
Glyn Normington is currently offline Glyn NormingtonFriend
OSGi bundles (and a .libd file) for Spring framework 3.2.0.RC1 have been added to the SpringSource EBR. Please note that the EBR web app filters out RC bundles, but you can use Ivy or Maven to download them.
Unfortunately, there are some pre-req. changes in Virgo which are needed for web applications on 3.2.x and we have not yet done the Eclipse IP review of 3.2.0.RC1. I am therefore making the following private builds available for download until at least 5 December (after which I'll delete them):
If you find any bugs in Spring framework, these can be raised using Spring framework JIRA. If you find any bugs in the OSGi manifests, these can be raised using SpringSource JIRA. Virgo bugs can be raised in the usual way.
Previous Topic:Write log message in a single file - virgo - common - logging
Next Topic:Virgo tools put test classes in staging dir
Current Time: Fri Jun 05 10:08:15 GMT 2020
Powered by FUDForum. Page generated in 0.01920 seconds
