Eclipse suddenly refuses to open [message #986575] |
Wed, 21 November 2012 02:32 |
Christian Selig Messages: 3 Registered: November 2012 |
I get the following error:
Error below. Does anyone know why this is happening?
An error has occurred. See the log file /Users/Christian/Dropbox/Projects/Java Projects/.metadata/.log.
And here's the log file's contents:
!SESSION 2012-10-07 11:31:23.698 -----------------------------------------------
eclipse.buildId=I20120608-1400
java.version=1.6.0_35
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/Christian/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -keyring /Users/Christian/.eclipse_keyring -showlocation
This is a continuation of log file /Users/Christian/Dropbox/Projects/Java Projects/.metadata/.bak_0.log
Created Time: 2012-10-07 17:11:53.710
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:11:53.710
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:276)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:494)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:545)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:366)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:313)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1072)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4133)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1458)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1495)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1491)
at org.eclipse.swt.widgets.Canvas.sendKeyEvent(Canvas.java:493)
at org.eclipse.swt.widgets.Control.doCommandBySelector(Control.java:1060)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5585)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSResponder.interpretKeyEvents(NSResponder.java:68)
at org.eclipse.swt.widgets.Composite.keyDown(Composite.java:587)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5495)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:221)
at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2102)
at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2284)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5557)
at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5002)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5151)
at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3616)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:775)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:569)
at org.eclipse.swt.widgets.Text.paste(Text.java:1409)
at org.eclipse.ui.internal.quickaccess.SearchField$12.execute(SearchField.java:286)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.GeneratedMethodAccessor25.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:18:12.047
!MESSAGE
!STACK 0
at org.eclipse.swt.widgets.Text.selectAll(Text.java:1586)
at org.eclipse.ui.internal.quickaccess.SearchField$9.execute(SearchField.java:268)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 17:18:12.679
!MESSAGE
!STACK 0
... 57 more
!SESSION 2012-10-07 17:22:17.518 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-07 17:22:24.387
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-07 17:22:24.843
!MESSAGE CSS property 'selected-tab-fill' has been deprecated: renamed as selected-tab-fill
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:01:20.356
!MESSAGE
!STACK 0
at org.eclipse.swt.widgets.Text.copy(Text.java:486)
at org.eclipse.ui.internal.quickaccess.SearchField$11.execute(SearchField.java:280)
at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:52:43.681
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 20:52:48.712
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 21:26:32.916
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 23:13:01.791
!MESSAGE
!STACK 0
... 57 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-10-07 23:13:02.775
!MESSAGE
!STACK 0
... 57 more
!SESSION 2012-10-07 23:31:59.670 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-07 23:32:05.810
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-07 23:32:06.273
!SESSION 2012-10-08 15:48:18.356 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-08 15:48:24.125
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-08 15:48:24.617
!SESSION 2012-10-14 19:06:52.136 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-14 19:06:58.422
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-14 19:06:58.866
!SESSION 2012-10-14 22:16:26.934 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2012-10-14 22:16:33.042
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-14 22:16:33.512
!ENTRY org.eclipse.jface.text 4 0 2012-10-14 22:21:39.287
!MESSAGE Unexpected runtime error while computing a text hover
!STACK 0
at org.eclipse.jdt.internal.corext.codemanipulation.StubUtility.getLineDelimiterUsed(StubUtility.java:823)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaSourceHover.getBracketHoverInfo(JavaSourceHover.java:141)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaSourceHover.getHoverInfo(JavaSourceHover.java:96)
at org.eclipse.jdt.internal.ui.text.java.hover.AbstractJavaEditorTextHover.getHoverInfo2(AbstractJavaEditorTextHover.java:84)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:163)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:129)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaEditorTextHoverProxy.getHoverInfo2(JavaEditorTextHoverProxy.java:85)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextViewerHoverManager.java:166)
!SESSION 2012-10-15 21:28:56.629 -----------------------------------------------
!ENTRY org.eclipse.e4.ui.css.core 4 0 2012-10-15 21:29:06.863
!SESSION 2012-10-17 22:05:30.332 -----------------------------------
FUDForum. Page generated in 0.09657 seconds
