Home » Eclipse Projects » Nebula » [Nebula Gallery] Reload images from directory in the same group
[Nebula Gallery] Reload images from directory in the same group [message #986303] Mon, 19 November 2012 19:34 Go to next message
Piotr Czajka is currently offline Piotr CzajkaFriend
I have a question related with nebula gallery. When I load images from selected directory gallery adds new groups (it's works perfect Smile) but when I want to open directory which was loaded previously is it possible to slide down old group and reload images there instead of adding new group ?
E.g. from my app in file attachment, I want to refresh images in E:\Images instead of create new
[Updated on: Tue, 20 November 2012 21:06]
Report message to a moderator
Re: [Nebula Gallery] Reload images from directory in the same group [message #986661 is a reply to message #986303] Wed, 21 November 2012 10:20 Go to previous messageGo to next message
Nicolas Richeton is currently offline Nicolas RichetonFriend
You can remove existing groups and items using Gallery#remove or GalleryItem#remove
Then add items/groups at any position of Gallery using GalleryItem(GalleryItem parent, int style, int index).
Or you can also update existing items, see Gallery#getItem(int index) and GalleryItem#getItem(int index)
If current documentation is not enough, you can also search for solution with Table or Tree since the basic API (adding/removing items) is exactly the same as Gallery.
Nicolas
Re: [Nebula Gallery] Reload images from directory in the same group [message #988947 is a reply to message #986661] Mon, 03 December 2012 23:55 Go to previous message
Thanks for reply it works very well Smile
[Updated on: Wed, 05 December 2012 17:40]
Previous Topic:[Grid] Duplicate Classes?
Next Topic:[Nebula Gallery] Update existing items, name of group when empty field was clicked
Current Time: Mon Dec 09 17:05:47 GMT 2024
Powered by FUDForum. Page generated in 0.04332 seconds
