Home » Newcomers » Newcomers » Can't find clone button!?
Can't find clone button!? [message #986256] Mon, 19 November 2012 16:24 Go to next message
Lalilu Lelo is currently offline Lalilu LeloFriend
Member
Hello everyone!
My teacher has posted a tutorial on how to grab projects from git and build them in my PC.
In the video, he goes to file > import > git > projects from git, then he pastes the url and clicks clone...
In my screen however there is no clone or add buttons... Am i missing something here ???
Also I have a newer version than the one in the vid..
Re: Can't find clone button!? [message #986281 is a reply to message #986256] Mon, 19 November 2012 17:23 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 11/19/2012 09:29 AM, george bakir wrote:
> Hello everyone!
> something here ???
I would suggest either doing the clone from the command line or posting
in the Eclipse eGit forum for help.
Re: Can't find clone button!? [message #986332 is a reply to message #986281] Tue, 20 November 2012 04:36 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
http://wiki.eclipse.org/EGit/User_Guide#Starting_from_existing_Git_Repositories (and some of what comes earlier on that page) should help.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Can't find clone button!? [message #986715 is a reply to message #986256] Wed, 21 November 2012 12:33 Go to previous messageGo to next message
Member
You see the picture on the link you posted ?
I don't have add / clone buttons on my screen..
*I made a new post on egit.
Re: Can't find clone button!? [message #986741 is a reply to message #986715] Wed, 21 November 2012 13:59 Go to previous messageGo to next message
On 11/21/2012 05:33 AM, george bakir wrote:
> You see the picture on the link you posted ? I don't have add / clone
Do you get this dialog box, though? Have you installed the eGit
plug-ins? It will be helpful (yeah, do this in the eGit forum) for you
to include an image of what you're (not) seeing.
Best of luck,
Russ
Re: Can't find clone button!? [message #986769 is a reply to message #986256] Wed, 21 November 2012 15:13 Go to previous messageGo to next message
Member
Here's the picture
Re: Can't find clone button!? [message #986825 is a reply to message #986769] Wed, 21 November 2012 19:29 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
On 11/21/2012 09:13 AM, george bakir wrote:
> Here's the picture
You are working with a newer version of Eclipse. The work flow is
slightly different. It clones repositories automatically when you
import from a URI. Select URI on the dialog you posted and click Next.
Fill in the repository information and click Next again. Select the
branches to clone. Click Next. Select the location where the repository
should be cloned. Click Next. Select Import existing projects. Click
Next. Select the projects to import and click Finish.
Re: Can't find clone button!? [message #986829 is a reply to message #986825] Wed, 21 November 2012 19:57 Go to previous messageGo to next message
Member
Hi and thanks for replying!
I think I have managed to clone it by following the process and ticking the existing (this time).
Ok, now I can see it all, navigate and make changes to the code but the build button is grayed out. When I go to compile it says there are no previous launches.
Any ideas ?
(My teacher isn't very helpfull and i don't know where to turn.. Little problems like these need to be solved in order for me to get on with my work. So I really appreciate for any help. )
Re: Can't find clone button!? [message #986853 is a reply to message #986829] Thu, 22 November 2012 04:11 Go to previous message
> previous launches.
> Any ideas ?
I would suggest you go through the Tutorials in the Help provided by
Eclipse. The Java Development User Guide has a basic tutorial that goes
over the development process of using Eclipse.
Previous Topic:permeability models
Next Topic:Eclipse Plugin Development
Current Time: Sun May 16 04:17:21 GMT 2021
Powered by FUDForum. Page generated in 0.02093 seconds
