Home » Newcomers » Newcomers » Java7 Compatibility with Eclipse(Eclipse won't run with Java7)
Java7 Compatibility with Eclipse [message #986063] Sun, 18 November 2012 02:54 Go to next message
Kevin Lennox is currently offline Kevin LennoxFriend
I recently started an Android programming course and downloaded Java Development Kit version 7 and ADT bundle for Windows (which has Eclipse bundled with it) and installed both. Eclipse would not run (see attached image) as it said that it was incompatible with my version of Windows (which is Windows 7 Home Premium).
I checked my course notes and it said "DO NOT USE the Java Development Kit version 7 as it is not fully compatible with current versions of Eclipse" and to use Version 6 Update 27 instead.
I have tried uninstalling Version 7 and installing 6 but Java installer still thinks a newer version is in existence. I try running Eclipse and it still won't run.
Any ideas?
index.php/fa/12430/0/
  • Attachment: Capture.PNG
    (Size: 30.07KB, Downloaded 544 times)
Re: Java7 Compatibility with Eclipse [message #986106 is a reply to message #986063] Sun, 18 November 2012 22:41 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
> Any ideas?
First, this isn't an Android programming forum.
Second, you don't need to uninstall JDK 7, just install a copy of JDK 6,
wire it up to Eclipse and you can get back to work. If you are mystified
by this answer, please read the first couple of articles in this
summary: http://www.javahotchocolate.com/tutorials/eclipse-summary.html .
Previous Topic:Updates and plugin installs are impossible
Next Topic:Recent and Open Projects feature in Eclipse IDE
Current Time: Tue May 17 21:53:52 GMT 2022
Powered by FUDForum. Page generated in 0.03081 seconds
