Home » Modeling » M2T (model-to-text transformation) » [Acceleo] EMTL files not contained in build
[Acceleo] EMTL files not contained in build [message #986042] |
Sat, 17 November 2012 19:58 |
Hi all,
don't know why this just started to fail (worked for several weeks without
problems) but from one day to another the build of the EMTL files, or more
precisely the export into my bundle via an update site, does not work
anymore. Well, not exactly from one day to another, I did refactor the
packages and the project name.
However, the Acceleo builder is active, the nature is set and the code
generation runs from within the started instance of my dev environment. The
EMTL files are not exported, neither by using an update site nor by using
"deployable plugins an fragments".
Funny things is that I created a new Acceleo project from scratch with the
same settings, and the EMTL files are generated properly for the newly
created project. I'm pretty sure the incorrect behavior must be related to
my refactorings and I'm hoping for some hints from you guys.
I'm using acceleo 3.2.0 with Indigo.
Any ideas?
Marc-Florian
Re: [Acceleo] EMTL files not contained in build [message #986075 is a reply to message #986042] |
Sun, 18 November 2012 11:11 |
Ed Willink Messages: 7655 Registered: July 2009 |
Don't use 3.2; it has a variety of builder issues, that make it
unuseable for me.
3.3 is much better, but even then particularly after a GIT branch change
it will fail to build EMTL's, but these appear after a trivial *.mtl edit.
Ed Willink
On 17/11/2012 19:58, Florian Wendland wrote:
> Hi all,
> without problems) but from one day to another the build of the EMTL
> files, or more precisely the export into my bundle via an update site,
> does not work anymore. Well, not exactly from one day to another, I
> did refactor the packages and the project name.
> environment. The EMTL files are not exported, neither by using an
> update site nor by using "deployable plugins an fragments".
> the same settings, and the EMTL files are generated properly for the
> newly created project. I'm pretty sure the incorrect behavior must be
> related to my refactorings and I'm hoping for some hints from you guys.
> Any ideas?
> Marc-Florian
Re: [Acceleo] EMTL files not contained in build [message #986145 is a reply to message #986075] |
Mon, 19 November 2012 08:19 |
Hi Ed,
thanks for your prompt response. Just tried with Acceleo 3.3.1, but with the
same - i.e. no at all - success. The EMTL files are still not generated.
Wow, that gives me really a headache.
Any further hints?
Marc-Florian
"Ed Willink" schrieb im Newsbeitrag news:k8afom$hnr$1@xxxxxxxxe.org...
unuseable for me.
Ed Willink
> Hi all,
> The EMTL files are not exported, neither by using an update site nor by
> Any ideas?
> Marc-Florian
Re: [Acceleo] EMTL files not contained in build [message #986169 is a reply to message #986145] |
Mon, 19 November 2012 09:55 |
For the Eclipse OCL distribution for which deployment on a Hudson server
gives additional difficulties, I redesignate *.emtl files as sources in
a src2 folder.
Building is then trivial; for an Acceleo-less configuration the Java
builder just copies src2/.../*.emtl to bin/.../*.emtl. Job done.
During development, I add the Acceleo nature, remove src2 from the
classpath and uncomment
#customBuildCallbacks = build.acceleo
in build.properties.
Once a development phase is finished; diff src2/.../*.emtl and
bin/.../*.emtl, update and commit to your CMS.
See GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.codegen\src2.
Ed Willink
On 19/11/2012 08:19, Florian Wendland wrote:
> Hi Ed,
> with the same - i.e. no at all - success. The EMTL files are still not
> generated.
> Any further hints?
> Regards,
> Marc-Florian
> Hi
> unuseable for me.
> edit.
> Regards
> Ed Willink
>> Hi all,
>> site, does not work anymore. Well, not exactly from one day to
>> another, I did refactor the packages and the project name.
>> code generation runs from within the started instance of my dev
>> with the same settings, and the EMTL files are generated properly for
>> the newly created project. I'm pretty sure the incorrect behavior
>> must be related to my refactorings and I'm hoping for some hints from
>> you guys.
>> Any ideas?
>> Marc-Florian
Current Time: Wed Apr 17 21:09:36 GMT 2024
Powered by FUDForum. Page generated in 0.02632 seconds
