Home » Modeling » TMF (Xtext) » Assignments and function output have same sintax(non-LL(*) decision)
Assignments and function output have same sintax [message #985883] Fri, 16 November 2012 14:51 Go to next message
Tommaso De Sica is currently offline Tommaso De SicaFriend
I've got a situation that can be summarized with this little code:
Instruction:
   EmptyInstruction | Assignment;
EmptyInstruction: ';';
Assignment:
   variable=[Variable]':='expression=Expression';' ;
Function:
   'FUNCTION' name=ID
   instructions+=Instruction*
   output=[Function]':='expression=Expression';' ;
I know where is the problem, but how can I resolve the non-LL decision?
Very thank you for help.
[Updated on: Fri, 16 November 2012 14:52]
Report message to a moderator
Re: Assignments and function output have same sintax [message #986163 is a reply to message #985883] Mon, 19 November 2012 09:22 Go to previous messageGo to next message
Boris Brodski is currently offline Boris BrodskiFriend
I see no problem with this (Xtext 2.3.1). Enhanced with some more rules it works for me:
Grammar:
Model:
	(functions += Function)*;
Instruction:
EmptyInstruction: {EmptyInstruction} ';';
Assignment:
Function:
   'FUNCTION' name=ID
   vars += Variable*
Variable: name=ID ';';
Expression: value=INT | var=[Variable];
DSL:
FUNCTION a
  b;
  c;
  b := 1;
  c := b;
  a := c;
Re: Assignments and function output have same sintax [message #986254 is a reply to message #986163] Mon, 19 November 2012 16:22 Go to previous messageGo to next message
I solve with option
backtrack=true
UPDATE:
Problem comes out also in this situation:
RealValue:
INT '.' INT;
Array:
name=ID 'ARRAY' '[' initial=INT '..' final=INT ']' ';';
When, in my DSL, I try to write something like this:
v ARRAY [1..10];
I'll receive an error: after the '.' it wants an INT.
Very thank you!
[Updated on: Mon, 19 November 2012 16:43]
Re: Assignments and function output have same sintax [message #986265 is a reply to message #986254] Mon, 19 November 2012 16:41 Go to previous messageGo to next message
RealValue:
INT '.' INT;
Array:
v ARRAY [1..10];
Very thank you!
Re: Assignments and function output have same sintax [message #986266 is a reply to message #986254] Mon, 19 November 2012 16:41 Go to previous messageGo to next message
RealValue:
INT '.' INT;
Array:
v ARRAY [1..10];
Very thank you!
Re: Assignments and function output have same sintax [message #986325 is a reply to message #986266] Tue, 20 November 2012 00:36 Go to previous messageGo to next message
backtrack=true
is strongly discouraged. It suspends all those warnings, so you have no idea, something else is broken too.
Besides that, you have no control, which way the parse will take ignoring the warning. Consider using syntactic predicated '=>' instead.
Re: Assignments and function output have same sintax [message #986358 is a reply to message #986325] Tue, 20 November 2012 08:47 Go to previous messageGo to next message
Boris Brodski wrote on Tue, 20 November 2012 01:36
backtrack=true
Very thank you for suggest, I was able to disable the backtrack. For the moment it works fine.
Now I'm going to finish the grammar,
thanks!
Re: Assignments and function output have same sintax [message #986612 is a reply to message #985883] Wed, 21 November 2012 08:19 Go to previous messageGo to next message
Maybe solved.
[Updated on: Thu, 22 November 2012 09:58]
Re: Assignments and function output have same sintax [message #987212 is a reply to message #986612] Sat, 24 November 2012 14:27 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
Ciao Tommaso
as they already told you, stay away from backtrack=true :)
you can find an example expression language here
http://xsemantics.sourceforge.net/xsemantics-documentation/Expressions-example.html#Expressions
hope this helps
Lorenzo
On 11/21/2012 09:19 AM, Tommaso De Sica wrote:
> Similar problem that I can't solve:
> Expression:
> (expression=NumericExpression) | (expression=BoolExpr)
> BoolExpr returns BoolExpr:
> OrExpr;
> OrExpr returns BoolExpr:
> AndExpr ({Or.left=current} 'OR' right=AndExpr)*;
> AndExpr returns BoolExpr:
> PrimaryExpr ({And.left=current} 'AND' right=PrimaryExpr)*;
> PrimaryExpr returns BoolExpr:
> '(' BoolExpr ')' | BoolLiteral;
> BoolLiteral:
> NumericExpression returns IntegerExpression:
> Multiplication ({NumericExpression.left=current} ('+'|'-')
> right=Multiplication)*;
> Multiplication returns IntegerExpression:
> Pow ({Multiplication.left=current} ('*'|'/'|'MOD') right=Pow)*;
> Pow returns IntegerExpression:
> Primary ({Pow.left=current} '**' right=Primary)*;
> Primary returns IntegerExpression:
> NumberLiteral |
> '(' NumericExpression ')' |
> '-'NumberLiteral;
> NumberLiteral:
> error is the same, but I can't understand how use => in this case.
> Someone can halp me? Very thank you!
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Assignments and function output have same sintax [message #987389 is a reply to message #987212] Mon, 26 November 2012 12:05 Go to previous messageGo to next message
Yes, I was able to rewrite the grammar unambiguous.
backtrack=true is just a memory Confused
Thanks for replies!
Re: Assignments and function output have same sintax [message #987390 is a reply to message #987389] Mon, 26 November 2012 12:17 Go to previous message
Very well (y)
Previous Topic:Running the Xtext machinery outside the builder
Next Topic:Strategies for using embedded editor
Current Time: Sat Oct 31 03:14:08 GMT 2020
Powered by FUDForum. Page generated in 0.02621 seconds
