Home » Newcomers » Newcomers » Eclipse not working?
Re: Eclipse not working? [message #985936 is a reply to message #985927] |
Fri, 16 November 2012 18:02 |
On 11/16/2012 10:21 AM, Jacob O wrote:
> (ok again im not sure if im doing this correctly)
> I already did a search about Java not working and Eclipse not working and already got that but im on mac and have no idea about what version i have etc. but i think i found out how to add a screenshot
> ^^Hopefullly you can see this
> ^^And these. So these are basically the errors i get on a simple program.
The JavaPractice project doesn't appear to have been set up as a Java
project. It's visibly missing JRE System Library. You might be able to
add this by right-clicking on the project, choosing Build Path ->
Configure Build Path, then click the Libraries tab and the Add
Library... button, then JRE System Library and add that. (If it didn't
start out as a Java project, then something else might be broken. It's
easier to start off life correctly.)
Re: Eclipse not working? [message #985954 is a reply to message #985950] |
Fri, 16 November 2012 20:54 |
On 11/16/2012 1:39 PM, Jacob O wrote:
> Thanks, right clicking and selcting the library works with that project but about creating a new project i click "new Java Project" and it for some reason doesn't put the library in as well..
Odd:
Re: Eclipse not working? [message #985957 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985960 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985964 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985966 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985969 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985971 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985972 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985973 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985974 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985975 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985976 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985977 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985979 is a reply to message #985950] |
Odd:
Re: Eclipse not working? [message #985981 is a reply to message #985950] |
Odd:
Current Time: Thu Apr 25 12:33:08 GMT 2024
Powered by FUDForum. Page generated in 0.10297 seconds
