Home » Archived » Buckminster » Make MWE archive available as P2 (Please).
Make MWE archive available as P2 (Please). [message #981375] Mon, 12 November 2012 11:09 Go to next message
Christophe Bouhier is currently offline Christophe BouhierFriend
I have a requirement on this components (1.1.0):
xtend
xpand
from p2 location:
http://archive.eclipse.org/modeling/m2t/xpand/downloads/drops/1.1.0/R201106070515/repository
Which in turn requires some older version of MWE (1.1.0), see screenshot.
I can't find a suitable version here:
http://www.eclipse.org/modeling/emft/downloads/?project=mwe
Can this please be made available?
thank you,
Christophe Bouhier
Re: Make MWE archive available as P2 (Please). [message #981478 is a reply to message #981375] Mon, 12 November 2012 12:54 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis HuebnerFriend
Christophe,
2.0.0 of MWE (called MWE2) contains some bundles that are not changed in major manner. This bundles still have the 1.1 version. So if I compare the build qualifier your build depends on R201106070634 2.0.0 release. You can you this archived site:
http://archive.eclipse.org/modeling/emft/mwe/downloads/drops/2.0.0/R201106070634/
Dennis.
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
Re: Make MWE archive available as P2 (Please). [message #981499 is a reply to message #981478] Mon, 12 November 2012 13:10 Go to previous messageGo to next message
Hi Dennis,
Bucky doesn't accept a .zip archive as a p2. (See error below).
Could you please to the same as you did for Xpand, which is unpack and add a link "repository".
Thanks! Christophe
ERROR [0009] : No suitable provider for component org.eclipse.emf.mwe.core:osgi.bundle was found in searchPath emft
ERROR [0009] : Rejecting provider p2(http://archive.eclipse.org/modeling/emft/mwe/downloads/drops/2.0.0/R201106070634/emft-mwe-2-Update-2.0.0.zip[http://archive.eclipse.org/modeling/emft/mwe/downloads/drops/2.0.0/R201106070634/emft-mwe-2-Update-2.0.0.zip]): No component match was found
ERROR No repository found at http://archive.eclipse.org/modeling/emft/mwe/downloads/drops/2.0.0/R201106070634/emft-mwe-2-Update-2.0.0.zip/
Re: Make MWE archive available as P2 (Please). [message #982820 is a reply to message #981499] Tue, 13 November 2012 12:53 Go to previous messageGo to next message
et voilĂ !
http://archive.eclipse.org/modeling/emft/mwe/downloads/drops/2.0.0/R201106070634/repository/
+Dennis Huebner
Re: Make MWE archive available as P2 (Please). [message #985817 is a reply to message #982820] Fri, 16 November 2012 09:39 Go to previous message
Thx Dennis!
Previous Topic:materialize projects-platform.cquery in eclipse
Next Topic:Dependency version mismatch when materializing a plugin
Current Time: Wed Mar 22 10:05:02 GMT 2023
Powered by FUDForum. Page generated in 0.02383 seconds
