Home » Eclipse Projects » Eclipse Platform » "Toggle Source/Header" interferes with "Next Editor" in Juno("Toggle Source/Header" interferes with "Next Editor" in Juno)
icon9.gif  "Toggle Source/Header" interferes with "Next Editor" in Juno [message #981339] Mon, 12 November 2012 10:40 Go to next message
Marco Binz is currently offline Marco BinzFriend
I just changed to Juno, and since then some key bindings don't work as expected anymore.
I have Ctrl+§ assigned to "Toggle Source/Header" in C/C++ Editor and Ctrl+Tab to "Next Editor" when Editing Text.
Ctrl+§ works as expected. Ctrl+Tab however only works in non C/C++ files, e.g. in xml files. In C/C++ files Ctrl+Tab does the same as Ctrl+§, it toggles between source and header.
What am I doing wrong?
Thanks for any help,
Marco
Re: "Toggle Source/Header" interferes with "Next Editor" in Juno [message #983084 is a reply to message #981339] Tue, 13 November 2012 17:02 Go to previous message
Marco Maccaferri is currently offline Marco MaccaferriFriend
> as expected anymore. I have Ctrl+§ assigned to "Toggle Source/Header"
> Ctrl+§, it toggles between source and header. What am I doing wrong?
Had the same problem using an old workspace created from previous
Eclipse versions and fixed doing the following: from the general -> keys
preference page click on restore defaults, then remove the binding from
toggle source/header and add ctrl+tab to next editor.
Hope this helps.
Previous Topic:CompareUI with Syntax Colouring
Next Topic:[text] actionSetPartAssociations deprecated -> how to replace this with commands?
Current Time: Tue Apr 16 23:13:16 GMT 2024
Powered by FUDForum. Page generated in 1.30020 seconds
