Generating XMI profiling files to be analyzed with TPTP [message #141680] |
Fri, 03 April 2009 19:34 |
Originally posted by: malloovidio.bluewin.ch
Hi all,
I am gathering some timing information in an RCP application using AspectJ
and I would like to save my timing results to an XMI file compatible to the
ones generated by TPTP in order to be able to analyze the gathered data
using the capabilities provided by TPTP. Therefore, I wanted to ask whether
there is some convenient way to generate the XMI files in a format suitable
for TPTP. AFAIK, the XMI files are the serialized form of an EMF model so
maybe I can simply build up some EMF model hierarchy from my data and
serialize it?
Thanks in advance for any help!
Ovidio
Re: Generating XMI profiling files to be analyzed with TPTP [message #141704 is a reply to message #141680] |
Mon, 06 April 2009 14:49 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi Ovidio,
You can set your output of your collection to the XML4Profiling format in
TPTP.
Detail of the event specification here:
http://www.eclipse.org/tptp/platform/documents/resources/pro filingspec/XML4Profiling.htm
If you want to see any example of the TPTP a profiling file, In your system,
set a global variable TPTP_OUTPUT_FORMAT=xml, then try profiling to file,
configurable in the destination tab of a profiling launch configuration, and
unzip the file created after the profiling session for inspection. It is a
pure XML file that you can see.
Eugene
"Ovidio Mallo" <malloovidio@bluewin.ch> wrote in message
news:gr5obp$vtq$1@build.eclipse.org...
> Hi all,
> the
> whether
> suitable
> serialize it?
> Best regards,
> Ovidio
FUDForum. Page generated in 0.03049 seconds
