Postgres inet type [message #980721] |
Sun, 11 November 2012 23:05 |
Neikius Mising name Messages: 43 Registered: April 2011 |
Member |
So, using eclipselink and inet type is nicely cast to string when reading.
But on insert something is wrong:
Caused by: org.postgresql.util.PSQLException: ERROR: column "..." is of type inet but expression is of type character varying
Hint: You will need to rewrite or cast the expression.
So I must override using descriptor customizer? Is kinda strange since I can insert into that column the IP as normal string.
This gets generated, nothing special (And it dies):
Call: INSERT INTO "table" (columns ...) VALUES (?, ?, ?, ?, ?, ?, ?)
bind => [7 parameters bound]
And this WORKS:
VALUES (... '127.0.0.1' ...);
So when I call an ordinary query I can pass inet field as standard string and it all works. When a prepared statement it called via eclipselink and inet is bound as a string everything dies. A bug certiainly, but is there any workaround or a trick to make it work? Converter doesn't seem to work.
Re: Postgres inet type [message #984694 is a reply to message #980721] |
Wed, 14 November 2012 22:37 |
Member |
Well I can always use a native query and I will for now.
@Chris: Yes it accepts param inet as inline string in a native query. The link you posted doesn't make it exactly clear (I am using java EE!) if I can just use @QueryHint annotation on a @Entity class to override the behaviour just for it? That would be perfect I guess. Does it do escaping if you do it like that automatically?
@James: The problem is I don't know. Manual doesn't say: http://www.postgresql.org/docs/9.2/static/datatype-net-types.html And yea, I am quite sure that is the problem. Strangely though it accepts string inline no problems. I guess I need to take this to postgre people.
[Updated on: Wed, 14 November 2012 22:44] Report message to a moderator
Re: Postgres inet type [message #985698 is a reply to message #980721] |
Thu, 15 November 2012 17:40 |
You need to add parameter ?stringtype=unspecified to your JDBC connection string. This is due to reason that inets in your query are explicitly casted to Strings by PostgreSQL JDBC driver.
FUDForum. Page generated in 0.03597 seconds
