Home » Archived » BIRT » BIRT JDBC and ODBC
BIRT JDBC and ODBC [message #141554] Wed, 08 March 2006 14:55 Go to next message
mr. burns is currently offline mr. burnsFriend
I try to get a JDBC-ODBC connection to work.
What I succesfully could do is creating a datasource:
DriverClass: sun.jdbc.odbc.JdbcOdbcDriver (Sun JDBC-ODBC Bridge Driver)
Database-URL: jdbc:odbc:MyODBC_DSN
Username: TestUser
Password: test
If I click on TestConnection it says me: Connection successful.
But If I do a simple query on a Table:
select * from Item
It gives me an error message within the dataset-wizard-->Result preview: ...
The result set type is not supported ...
(see attachment)
So what does it mean: The result set type is not supported?
Any idea is highly appreciated!
  • Attachment: odbc.jpg
    (Size: 51.26KB, Downloaded 476 times)
Re: BIRT JDBC and ODBC [message #141860 is a reply to message #141554] Wed, 08 March 2006 20:25 Go to previous messageGo to next message
> Username: TestUser
> Password: test
if you are working with MS SQL Server it's better to use driver from:
http://www.microsoft.com/downloads/details.aspx?familyid=e22 bc83b-32ff-4474-a44a-22b6ae2c4e17&displaylang=en
it published 1/19/2006
my settings:
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="midwood" id="5">
<property
name="odaDriverClass">com.microsoft.sqlserver.jdbc.SQLServerDriver </property>
<property
name="odaURL">jdbc:sqlserver://data-server-1:1433;DatabaseName=MedBase</property>
<property name="odaUser">username</property>
</oda-data-source>
Re: BIRT JDBC and ODBC [message #141977 is a reply to message #141860] Thu, 09 March 2006 11:50 Go to previous messageGo to next message
Hello Vladimir,
sorry I did not mention.
I use Navision Attain Native C/SIDE database which comes with a C/ODBC
driver.
Any ideas?
Re: BIRT JDBC and ODBC [message #1022617 is a reply to message #141977] Fri, 22 March 2013 08:49 Go to previous message
Uwe Hartl is currently offline Uwe HartlFriend
I am in the same situation now. Is there a solution to this?
Best regards
Uwe
Previous Topic:How to set axis tick labels?
Next Topic:oda.flatfile.InvalidResourceException
Current Time: Thu Sep 21 20:36:56 GMT 2023
Powered by FUDForum. Page generated in 0.02271 seconds
