Re: IWAT0005E The host localhost was not found.? [message #141028 is a reply to message #141017] |
Fri, 06 March 2009 11:19 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi David,
What version of TPTP? Are you using the Intergrated Agent Controller or
Agent Controller? Is there a firewall on your local machine?
If using an earlier version than TPTP 4.5, you may be running into:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221278
Paul
"David " <david.samuelsson@skatteverket.se> wrote in message
news:ccbdbcfabebbcfc4af70e68f2effaf7c$1@www.eclipse.org...
>I completed the AGR setup and tried to run this through an ANT script.
> testing the AGR inside Eclipse works fine in quick and standard mode. When
> using it in an ant script i get this very weird error:
> output from ant script:
> Buildfile: F:\workspace001\se.rsv.eclipse.testing\test.xml
> platform-verification:
> [echo] Verifying connection...
> [condition] Verification started!
> [condition] Verifying connection:
> [condition] {connectionString=tptp:rac://localhost:10002/default,
> specification=tptp, serverClass=rac, host=localhost, port=10002,
> serverInstance=/default, user=null, password=null}
> [condition] The specified agent controller
> 'tptp:rac://localhost:10002/default' is up and running!
> [condition] Verification completed!
> test-execution:
> [tptp:execution] Adding file
> "F:\workspace001\se.rsv.eclipse.testing\Testsuite.testsuite".
> [tptp:execution] Test execution started.
> [tptp:execution] Test 'Testsuite.testsuite' started.
> [tptp:execution] Preparing launch delegate...
> [tptp:execution] Performing pre-launch check...
> [tptp:execution] Performing final launch validation...
> [tptp:execution] Initializing source locator...
> [tptp:execution] Launching delegate...
> [tptp:execution] org.eclipse.core.runtime.CoreException: IWAT4039E The
> Test Execution Harness reported the following problems: IWAT0005E The host
> [tptp:execution] at
> org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:225)
> [tptp:execution] at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
> [tptp:execution] at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
> [tptp:execution] at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:607)
> [tptp:execution] at
> org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.launch(AbstractTestExecutionService.java:822)
> [tptp:execution] at
> org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:592)
> [tptp:execution] at
> org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
> [tptp:execution] at
> org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:139)
> [tptp:execution] at
> org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
> [tptp:execution] at java.lang.Thread.run(Unknown Source)
> anyone have a clue what can cause this? as i do try to use localhost as an
> condition before the test is started!
FUDForum. Page generated in 0.02130 seconds
