Home » Modeling » OCL » how to call OCL constraints( generated java source code of model ) from the main code of java(want to validate OCL constraints generated in source code from java code)
how to call OCL constraints( generated java source code of model ) from the main code of java [message #976833] Thu, 08 November 2012 22:07 Go to next message
Ekansh Missing name is currently offline Ekansh Missing nameFriend
am using OCL constraints on ecore model and generating code. So the thing is as simple as this I have a class Task having attribute startDate and endDate it has an ocl constraint :- invariant which states startDate < endDate.
I have generated java code for this project and there is a java class :
public class TmsValidator extends EObjectValidator {
  //what is diagnosticChain and context in the below method
  public boolean validateTask_C2(Task task, DiagnosticChain diagnostics, Map<Object, Object context) {
    return validate(TmsPackage.Literals.TASK,
         task,
         diagnostics,
         context,
         "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot",
         "C2",
         TASK__C2__EEXPRESSION,
         Diagnostic.ERROR,
         DIAGNOSTIC_SOURCE,
         0);
So from my main class, how do I validate my task here . I want to call the OCL constraint to check if startDate(Start Date) is less than endDate(End Date)
 // How do I validate my task here  . I want to call the
    //OCL constraint to check if startDate is less than endDate
// this is what I am doing
		Map<Object, Object> context = new HashMap<Object, Object>();
		BasicDiagnostic diag = new BasicDiagnostic();
		Task t=  TmsFactory.eINSTANCE.createTask();
		boolean flag =TmsValidator.INSTANCE.validateTask_C2(t, diag, context);
		System.out.println(flag);
Re: how to call OCL constraints( generated java source code of model ) from the main code of java [message #977315 is a reply to message #976833] Fri, 09 November 2012 07:15 Go to previous message
From the EMF Java
* Validates the object in the given context, optionally producing
diagnostics.
* @param diagnostics a place to accumulate diagnostics; if it's
<code>null</code>, no diagnostics should be produced.
* @param context a place to cache information, if it's
<code>null</code>, no cache is supported.
* @return whether the object is valid.
boolean validate(EObject eObject, DiagnosticChain diagnostics,
Map<Object, Object> context);
In practice the 'context' is pre-initialized by the normal EMF
invocation with usefuil helpers such as a SubstitutionLabelProvider.
Ed Willink
> task,
> diagnostics,
> context,
> "C2",
> Diagnostic.ERROR,
> DIAGNOSTIC_SOURCE,
> 0); }
> endDate(End Date)
> public static void main(String[] args) {
> // How do I validate my task here . I want to call the //OCL
> constraint to check if startDate is less than endDate // this is what
> I am doing
> context);
Previous Topic:enriching code with ocl
Next Topic:OCL Interpreter in Java (Helios)
Current Time: Mon Sep 09 14:33:45 GMT 2024
Powered by FUDForum. Page generated in 0.04264 seconds
