Exception when trying to observe a value for a particular key in an EMap [message #975544] |
Wed, 07 November 2012 23:55 |
William Saar Messages: 16 Registered: July 2009 |
I am trying to create an observable that tracks the value of the entry with key "param1" in an EMF-model EMap to bind it to a SWT control, but I get the exception at the bottom. Is it possible to observe the value of a key in an EMF map? or is there another way?
IEMFMapProperty mapProperty = EMFEditProperties.map(editingDomain, ModelPackage.eINSTANCE.getSettings_Parameters());
IObservableMap map = mapProperty.observe(SWTObservables.getRealm(Display.getCurrent()), settings.getParameters());
context.bindValue(SWTObservables.observeSelection(param1Scale), Observables.observeMapEntry(map, "param1"));
Exception:
java.lang.ClassCastException: org.eclipse.emf.ecore.util.EcoreEMap cannot be cast to org.eclipse.emf.ecore.EObject
at org.eclipse.emf.databinding.internal.EMFMapProperty.doGetMap(EMFMapProperty.java:87)
at org.eclipse.core.databinding.property.map.MapProperty.getMap(MapProperty.java:56)
at org.eclipse.core.internal.databinding.property.map.SimplePropertyObservableMap.getMap(SimplePropertyObservableMap.java:128)
at org.eclipse.core.internal.databinding.property.map.SimplePropertyObservableMap.access$0(SimplePropertyObservableMap.java:127)
at org.eclipse.core.internal.databinding.property.map.SimplePropertyObservableMap$3.run(SimplePropertyObservableMap.java:106)
at org.eclipse.core.databinding.observable.Realm$1.run(Realm.java:148)
at org.eclipse.core.databinding.observable.Realm.safeRun(Realm.java:152)
at org.eclipse.core.databinding.observable.Realm.exec(Realm.java:170)
at org.eclipse.core.internal.databinding.property.map.SimplePropertyObservableMap.firstListenerAdded(SimplePropertyObservableMap.java:104)
at org.eclipse.core.databinding.observable.map.AbstractObservableMap$PrivateChangeSupport.firstListenerAdded(AbstractObservableMap.java:50)
at org.eclipse.core.databinding.observable.ChangeManager.addListener(ChangeManager.java:70)
at org.eclipse.core.databinding.observable.ChangeSupport.addListener(ChangeSupport.java:30)
at org.eclipse.core.databinding.observable.map.AbstractObservableMap.addMapChangeListener(AbstractObservableMap.java:98)
at org.eclipse.core.databinding.observable.map.DecoratingObservableMap.firstListenerAdded(DecoratingObservableMap.java:82)
at org.eclipse.core.databinding.observable.map.DecoratingObservableMap.addMapChangeListener(DecoratingObservableMap.java:48)
at org.eclipse.core.internal.databinding.observable.MapEntryObservableValue.<init>(MapEntryObservableValue.java:78)
at org.eclipse.core.databinding.observable.Observables.observeMapEntry(Observables.java:591)
at org.eclipse.core.databinding.observable.Observables.observeMapEntry(Observables.java:564)
MediaOrgan - media organizer for your local computer and the web using Eclipse RCP/RAP - http://mediaorgan.com
Re: Exception when trying to observe a value for a particular key in an EMap [message #975825 is a reply to message #975544] |
Thu, 08 November 2012 05:18 |
Ed Merks Messages: 33140 Registered: July 2009 |
William,
The individual Map.Entry instances in an EMap feature in a model are
also EObjects and can be observed like any other EObject, but the EMap
as a whole isn't an EObject. You shouldn't change the key feature of a
map entry; it will corrupt the map index once there is an index.
On 08/11/2012 12:55 AM, William Saar wrote:
> Exception:
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Ed Merks
Re: Exception when trying to observe a value for a particular key in an EMap [message #976981 is a reply to message #975825] |
Fri, 09 November 2012 00:50 |
Ok, I don't see how I am changing the key from the public APIs I'm calling so maybe there is a problem with their implementation?
I thought I was using a map property binding mechanism implemented for this exact problem after the discussion in this thread
http://www.eclipse.org/forums/index.php/mv/msg/135844/427374/
...but I was never really certain about the outcome of that thread (the APIs don't seem to contain a method such as the EMFObservables#observeMapEntry-method that is discussed there).
Anyway, I solved it by adding the following helper method, but it would be nice for EMF-databindings to support it directly
private IObservableValue observeSettingsValue(EditingDomain editingDomain, final EMap parameters, String key, EStructuralFeature valueFeature) {
if (parameters.indexOfKey(key) < 0) {
parameters.put(key, null);
return EMFEditObservables.observeValue(SWTObservables.getRealm(Display.getCurrent()),
editingDomain,
(EObject) parameters.get(parameters.indexOfKey(key)),
valueFeature);
Re: Exception when trying to observe a value for a particular key in an EMap [message #977160 is a reply to message #976981] |
Fri, 09 November 2012 04:23 |
William,
Comments below.
No, I'm just warning you in advance of any attempts to do so.
See what Tom says...
We'll wait for Tom's reaction. He's the responsible committer for the
data binding APIs...
> valueFeature) {
> return
> editingDomain, (EObject)
> valueFeature);
Ed Merks
FUDForum. Page generated in 0.03444 seconds
