VE, Eclipse 3.3, and Vista [message #140007] |
Tue, 28 August 2007 21:29 |
Originally posted by: mucous.gmail.com
Is anyone running Erik Hecht's version of the VE for Eclipse 3.3
on Vista? I'm having a few problems that show up as "socket refused"
in the .log
However, turning on and off the Windows firefall has no effect.
I'm just curious if anyone has this combination working.
Re: VE, Eclipse 3.3, and Vista [message #140029 is a reply to message #140007] |
Wed, 29 August 2007 03:12 |
Originally posted by: wolfgang_baltes.hotmail.com
Hi Denis,
I have this combination working. But everytime I upgrade or change the
eclipse configuration (adding a plugin) I run into the same problem you are.
The fix is to remove the eclipse entries from the firewall and then reboot
the system. I don't fully understand why the reboot is required, but this
makes things work. I should also mention that I use the Symatec Antivirus
solution, and not Microsoft's.
After the reboot and after starting eclipse, I get a firewall prompt asking
whether I want to grant network access to the software. Reply with yes!
I hope this helps,
Wolfgang.
"Denis Yuen" <mucous@gmail.com> wrote in message
news:fb24j2$2j9$1@build.eclipse.org...
> in the .log
> Thanks
Re: VE, Eclipse 3.3, and Vista [message #616409 is a reply to message #140007] |
Wolfgang Messages: 12 Registered: July 2009 |
Hi Denis,
I hope this helps,
Wolfgang.
> in the .log
> Thanks
FUDForum. Page generated in 0.04109 seconds
