Re: VE does not show up in my 3.3 installation [message #139552 is a reply to message #139540] |
Fri, 03 August 2007 14:16 |
--------------000204060108000505030604
Rob,
Are you using a 5.0 JRE? Try running with -clean -debug and have a
close look at the Error log view for clues...
Rob Roy wrote:
> Yes, I tried -clean and still nothing.
> The Eclipse version I have is
> Version: 3.3.0
> Build id: 120070625-1500
> The zip file for the VE upgrade has paths specifying
> ve_eclipse_33_win32\features and \plugins. I extracted the \features files
> to the features folder under eclipse and the \plugins files to the plugings
> folder under eclipse. All the other features I have on my system are in
> their own subfolder under features. I tried creating folders with the same
> name as the jar files and then extracting the contents of the jar files to
> those folders and still I got nothing.
> Is there anything else that I can try to get VE to show up?
> Rob
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:f8t90c$8bl$2@build.eclipse.org...
>> Rob,
>> Did you run eclipse.exe -clean after unzipping the new plugins so that the
>> old configuration is cleaned up and a new configuration to that knows
>> about the new plugins is created?
>> Rob Roy wrote:
>>> I installed Eclipse 3.3 and then I added the files from
>>> ve_eclipse_33_win32.zip which I got from
>>> http://www.ehecht.com/eclipse_ve/ve.html and still saw nothing. Any ideas
>>> why?
>>> Thanks,
>>> Rob
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Rob,<br>
<br>
close look at the Error log view for clues...<br>
<br>
<br>
Rob Roy wrote:
<blockquote cite="mid:f8vd43$6tp$1@build.eclipse.org" type="cite">
<pre wrap="">Yes, I tried -clean and still nothing.
Version: 3.3.0
Rob
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:f8t90c$8bl$2@build.eclipse.org">news:f8t90c$8bl$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Rob,
Rob Roy wrote:
</pre>
<pre wrap="">I installed Eclipse 3.3 and then I added the files from
<a class="moz-txt-link-freetext" href="http://www.ehecht.com/eclipse_ve/ve.html">http://www.ehecht.com/eclipse_ve/ve.html</a> and still saw nothing. Any ideas
why?
Rob
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000204060108000505030604--
Re: VE does not show up in my 3.3 installation [message #616365 is a reply to message #139540] |
Ed Merks Messages: 33136 Registered: July 2009 |
Rob,
> Version: 3.3.0
> Rob
>> Rob,
>>> why?
>>> Thanks,
>>> Rob
<html>
<head>
</head>
Rob,<br>
<br>
<br>
<br>
Version: 3.3.0
Rob
</pre>
<pre wrap="">Rob,
Rob Roy wrote:
</pre>
why?
Rob
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.01933 seconds
