Using Babel to translate default dialogs in a e4 Application. [message #973388] |
Tue, 06 November 2012 09:40  |
I am trying to import Babel Project bundles into my e4 application,
What i did was:
importing the babel german-package into my target platform:
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.babel.nls_datatools_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_eclipse_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_modeling.emf_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_modeling.emf.cdo_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_modeling.gmp.gmf-tooling_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_mylyn_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_technology.actf_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_technology.koneki_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_technology.packaging.mpc_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_technology.subversive_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_tools.cdt_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_tools.cdt.tcf_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_tools.gef_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_tools.pdt_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_tools.tm_de.feature.group" version="4.2.0.v20120721043402"/>
<unit id="org.eclipse.babel.nls_webtools_de.feature.group" version="4.2.0.v20120721043402"/>
<repository location="http://download.eclipse.org/technology/babel/update-site/R0.10.0/juno"/>
Unfortunately there are some plugins missing:
Question:
Where can I find the missing plugins?
Is loading the language packages - all I need to use the translations from Babel project? is there some customization to do?
Re: Using Babel to translate default dialogs in a e4 Application. [message #974859 is a reply to message #974431] |
Wed, 07 November 2012 11:41   |
Thnx Kit, I could resolve the missing dependencies,
on "Add required Plugins" in Eclipse the following plugins where added: see [ ATTACHEMENT1 ]
The Problem is now, that when using tycho to build my application the following Error is thrown. see [ ATTACHEMENT2 ]
When building in Eclipse IDE - everything works fine.
Adding "org.eclipse.swt" or package "org.eclipse.swt.widgets" to my plugin's dependencies did not help.
As said here, the thrown Error is caused by the one of Babel's Plugins.
Question: do someone have expirience in compiling a e4 Application with tycho, wich Babel Plugin's loaded?
[ ATTACHEMENT1 ]:
org.eclipse.ant.core.nl_de@default:false
org.eclipse.core.commands.nl_de@default:false
org.eclipse.core.contenttype.nl_de@default:false
org.eclipse.core.databinding.beans.nl_de@default:false
org.eclipse.core.databinding.nl_de@default:false
org.eclipse.core.databinding.observable.nl_de@default:false
org.eclipse.core.databinding.property.nl_de@default:false
org.eclipse.core.expressions.nl_de@default:false
org.eclipse.core.filesystem.nl_de@default:false
org.eclipse.core.filesystem.win32.x86_64.nl_de@default:false
org.eclipse.core.jobs.nl_de@default:false
org.eclipse.core.resources.nl_de@default:false
org.eclipse.core.runtime.nl_de@default:false
org.eclipse.core.variables.nl_de@default:false
org.eclipse.e4.core.commands.nl_de@default:false
org.eclipse.e4.core.contexts.nl_de@default:false
org.eclipse.e4.core.di.extensions.nl_de@default:false
org.eclipse.e4.core.di.nl_de@default:false
org.eclipse.e4.core.services.nl_de@default:false
org.eclipse.e4.ui.bindings.nl_de@default:false
org.eclipse.e4.ui.css.core.nl_de@default:false
org.eclipse.e4.ui.css.swt.nl_de@default:false
org.eclipse.e4.ui.css.swt.theme.nl_de@default:false
org.eclipse.e4.ui.di.nl_de@default:false
org.eclipse.e4.ui.model.workbench.nl_de@default:false
org.eclipse.e4.ui.services.nl_de@default:false
org.eclipse.e4.ui.widgets.nl_de@default:false
org.eclipse.e4.ui.workbench.addons.swt.nl_de@default:false
org.eclipse.e4.ui.workbench.nl_de@default:false
org.eclipse.e4.ui.workbench.renderers.swt.nl_de@default:false
org.eclipse.e4.ui.workbench.swt.nl_de@default:false
org.eclipse.e4.ui.workbench3.nl_de@default:false
org.eclipse.equinox.app.nl_de@default:false
org.eclipse.equinox.common.nl_de@default:false
org.eclipse.equinox.ds.nl_de@default:false
org.eclipse.equinox.event.nl_de@default:false
org.eclipse.equinox.http.jetty.nl_de@default:false
org.eclipse.equinox.http.servlet.nl_de@default:false
org.eclipse.equinox.preferences.nl_de@default:false
org.eclipse.equinox.registry.nl_de@default:false
org.eclipse.equinox.util.nl_de@default:false
org.eclipse.help.base.nl_de@default:false
org.eclipse.help.nl_de@default:false
org.eclipse.jetty.http.nl_de@default:false
org.eclipse.jface.databinding.nl_de@default:false
org.eclipse.jface.nl_de@default:false
org.eclipse.osgi.nl_de@default:false
org.eclipse.osgi.services.nl_de@default:false
org.eclipse.swt.nl_de@default:false
org.eclipse.swt.win32.win32.x86_64.nl_de@default:false
org.eclipse.team.core.nl_de@default:false
org.eclipse.ui.forms.nl_de@default:false
org.eclipse.ui.intro.nl_de@default:false
org.eclipse.ui.nl_de@default:false
org.eclipse.ui.win32.nl_de@default:false
org.eclipse.ui.workbench.nl_de@default:false
[ ATTACHEMENT2 ]:
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:0.15.0:compile (default-compile) on project de.ivu.fare.rcp.plugin: Compilation failure: Compilation failure:
[ERROR] D:\1PROJEKTE\Neuentwicklung\de.ivu.fare.rcp\de.ivu.fare.rcp.plugin\src\main\java\de\ivu\fare\rcp\gui\preferences\PreferenceControl.java:[0,0]
[ERROR] package de.ivu.fare.rcp.gui.preferences;
[ERROR] ^
[ERROR] The type org.eclipse.swt.widgets.Button cannot be resolved. It is indirectly referenced from required .class files
[ERROR] 1 problem (1 error)
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:0.15.0:compile (default-compile) on project de.ivu.fare.rcp.plugin: Compilation failure
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:213)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:84)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBuild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:320)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:352)
Caused by: copied.org.apache.maven.plugin.CompilationFailureException: Compilation failure
at copied.org.apache.maven.plugin.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:418)
at org.eclipse.tycho.compiler.AbstractOsgiCompilerMojo.execute(AbstractOsgiCompilerMojo.java:179)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:101)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:209)
... 19 more
FUDForum. Page generated in 0.04430 seconds
