Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » GenModel Doc in Ecore Diagram Editor
GenModel Doc in Ecore Diagram Editor [message #139266] Mon, 27 July 2009 15:57 Go to next message
Originally posted by: formatzeh.gmx.de
I want to know for what this option is good for in the properties view
of the Ecore Diagram Editor? I'm asking because I want to add some
documentation to the metaclasses in my metamodel. I thought that this
options is good for this as the name suggests it. But when I start the
second Eclipse instance with the generated editor I can't see my text in
that field on the elements being instances of the metaclass where I
added the documentation. So for what is it good for?
regards
Gilbert
Re: GenModel Doc in Ecore Diagram Editor [message #139291 is a reply to message #139266] Mon, 27 July 2009 16:38 Go to previous messageGo to next message
Gilbert,
I think you need to change Suppress GenModel Annotations to false.
> regards
> Gilbert
Ed Merks
Re: GenModel Doc in Ecore Diagram Editor [message #139303 is a reply to message #139291] Mon, 27 July 2009 17:13 Go to previous messageGo to next message
Ed Merks wrote:
> Gilbert,
Ok I did it. And where do I see the documenting text of the metaclass in
the second eclipse instance containing the generated editor?
Re: GenModel Doc in Ecore Diagram Editor [message #369100 is a reply to message #139303] Tue, 28 July 2009 15:17 Go to previous messageGo to next message
Jacques LESCOT is currently offline Jacques LESCOTFriend
Gilbert,
That documentation is included in the generated code of your Java model.
For example, if you have created a Metaclass named "Element", if you
look into the generated Element.java class, you should see your text in
the Javadoc associated with that interface.
If you wish to customize the message shown in the bottom status bar of
the generated tree structure editor when you select an attribute in the
Properties View, you can perform that in the *.genmodel file, through
the "Property description" field when you have selected a Feature.
Jacques
Gilbert Mirenque a écrit :
> Ed Merks wrote:
>> Gilbert,
Re: GenModel Doc in Ecore Diagram Editor [message #369108 is a reply to message #369100] Tue, 28 July 2009 16:06 Go to previous message
Thanks Jacques, this is a beginning :)
Re: GenModel Doc in Ecore Diagram Editor [message #621260 is a reply to message #139266] Mon, 27 July 2009 16:38 Go to previous message
Gilbert,
> regards
> Gilbert
Ed Merks
Re: GenModel Doc in Ecore Diagram Editor [message #621262 is a reply to message #139291] Mon, 27 July 2009 17:13 Go to previous message
Ed Merks wrote:
> Gilbert,
Re: GenModel Doc in Ecore Diagram Editor [message #621272 is a reply to message #139303] Tue, 28 July 2009 15:17 Go to previous message
Gilbert,
Jacques
> Ed Merks wrote:
>> Gilbert,
Re: GenModel Doc in Ecore Diagram Editor [message #621277 is a reply to message #369100] Tue, 28 July 2009 16:06 Go to previous message
Previous Topic:Any difference between .ecorediag and .ecore_diagram?
Next Topic:Is it possible to split an editor window in EMF
Current Time: Tue Apr 16 23:30:23 GMT 2024
Powered by FUDForum. Page generated in 0.58535 seconds
