blueprint configuration eclipse juno [message #971920] |
Mon, 05 November 2012 08:09 |
nic wurst Messages: 1 Registered: November 2012 |
Junior Member |
iam new to gemini blueprint and need some help for the first configuration.
i created via the wizard (eclipse juno) the rcp mail template examble. then i created a new target definition where i added all required libs (spring, gemini blueprint) and setted this to my target platform.
After that, i created META-INF/spring/context.xml with a dummy bean definition:
<bean id="dummyServiceImpl" class="service.DummyServiceImpl" />
<osgi:service id="dummyService" interface="service.IDummyService" ref="dummyServiceImpl" />
</beans>
then in the plugin.xml, i added all spring and blueprint and the org.eclipse.rcp, org.eclipse.ui and org.eclipse.core libs to the list of required plugins.
Also in my run configuration, i marked all spring and gemini libs(plugins).
When i run this configuration, the rcp mail examble starts CORRECT, but no spring context were loaded.
here is the output from my console:
!SESSION 2012-11-05 08:58:21.565 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_29
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product de.wu.Test
Command-line arguments: -product de.wu.Test.product -data C:\Users\**\workspace/../runtime-de.wu.Test.product -dev file:C:/Users/**/workspace/.metadata/.plugins/org.eclipse.pde.core/de.wu.Test.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 2 1 2012-11-05 08:58:22.283
!MESSAGE NLS unused message: LAUNCHER_INVALID_PORT in: org.eclipse.osgi.framework.internal.core.ExternalMessages
!ENTRY org.eclipse.osgi 2 1 2012-11-05 08:58:22.493
!MESSAGE NLS unused message: ADAPTOR_DIRECTORY_REMOVE_EXCEPTION in: org.eclipse.osgi.internal.baseadaptor.ExternalMessages
!MESSAGE NLS unused message: ADAPTOR_ERROR_GETTING_MANIFEST in: org.eclipse.osgi.internal.baseadaptor.ExternalMessages
!ENTRY org.eclipse.osgi 2 1 2012-11-05 08:58:22.494
!MESSAGE NLS unused message: ADAPTOR_DATA_AREA_NOT_SET in: org.eclipse.osgi.internal.baseadaptor.ExternalMessages
!ENTRY org.eclipse.osgi 2 1 2012-11-05 08:58:22.495
!MESSAGE NLS unused message: BUNDLE_CLASSPATH_PROPERTIES_ERROR in: org.eclipse.osgi.internal.baseadaptor.ExternalMessages
log4j:WARN No appenders could be found for logger (org.eclipse.gemini.blueprint.extender.internal.boot.ChainActivator).
log4j:WARN Please initialize the log4j system properly.
when i hit "find unused dependencies", he shows me all spring libs.
I didnt find much information how to configure the first blueprint project, if anyone could give me some information i would be very glad.
Thank you.
Ulf
FUDForum. Page generated in 0.03098 seconds
