Re: Problems at RAP installation in Eclipse IDE 3.5 [message #139095 is a reply to message #139071] |
Thu, 02 July 2009 21:50 |
Benjamin Muskalla Messages: 338 Registered: July 2009 |
Hi Heiko,
we need to differentiate here between the tooling for RAP (Launcher,
Help, etc) and the real runtime (the APIs you're working with).
The Galileo update site provides both:
* the Tooling to install it into your IDE (see "Web, XML, and Java EE
Development" category)
* the Runtime to provision your target platform (see "Eclipse RT Target
Platform Components" category)
You should install the tooling in your IDE. The tooling itself will help
you to install the target (see the RAP entry on the intro after
restarting your IDE).
We're sorry for the confusion :-)
Greets
Ben
Heiko Ahlig wrote:
> HI,
> I try to install the RAP feature in a real fresh eclipse 3.5 (Classic)
> instance.
> First I try it with the "Install new software" and select the the entry
> -> RAP.
> (Search required software is checked)
> After the wizard checks, I've got the message:
> Cannot complete the install because one or more required items could not
> be found.
> Software being installed: Rich Ajax Platform (RAP) 1.2.0.20090616-1425
> (org.eclipse.rap.sdk.feature.group 1.2.0.20090616-1425)
> Missing requirement: Rich Ajax Platform (RAP) 1.2.0.20090616-1425
> (org.eclipse.rap.sdk.feature.group 1.2.0.20090616-1425) requires
> 'A.PDE.Target.Platform Cannot be installed into the IDE [0.0.0]' but it
> could not be found
> Ok maybee I have to install a target platform so I try with the infos
> from:
> http://www.eclipse.org/rap/downloads/runtime-install.php
> This works, but after them there is also no option to generate RAP
> projects.
> Again "Install new softwar"e an seletct RAP but the same error like before.
> What do I wrong?
> Regard,
> Heiko
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Problems at RAP installation in Eclipse IDE 3.5 [message #139130 is a reply to message #139071] |
Thu, 02 July 2009 22:20 |
Hi Heiko,
seems that this is going to become an FAQ ...
You want to install the RAP Tooling. The RAP Tooling also installs the
target platform for you. It is included in the category "Web, XML, and
Java EE Development".
The RAP Runtime SDK cannot be installed into the IDE. That's why you get
the error: "A.PDE.Target.Platform Cannot be installed into the IDE [0.0.0]".
To install the RAP Runtime SDK into a target definition, you have to
uncheck the checkbox "Include required software".
There is no such thing as a "RAP project". RAP projects are plug-in
projects. But there are templates to generate simple RAP applications.
References:
* http://www.eclipse.org/rap/downloads/
* http://www.eclipse.org/rap/gettingstarted.php
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=281854
* https://bugs.eclipse.org/bugs/show_bug.cgi?id=276000
Regards, Ralf
Heiko Ahlig wrote:
> HI,
> instance.
> -> RAP.
> be found.
> could not be found
> from:
> projects.
> What do I wrong?
> Regard,
> Heiko
FUDForum. Page generated in 0.03223 seconds
