Home » Archived » Buckminster » create a site.p2 from the target platform
Re: create a site.p2 from the target platform [message #970718 is a reply to message #969943] |
Sun, 04 November 2012 08:26   |
Hi Lorenzo,
On 2012-11-03 18:57, Lorenzo Bettini wrote:
> However, when I run site.p2 on this target.feature project it soon
> complains about
> No component named org.apache.ant:osgi.bundle/[1.7.0,2.0.0) is known to
> Buckminster
> which actually is not in the target platform (and probably needed by
> some of the bundles in the target platform?)
> so I was wondering: is there a way to create a p2 site from a target
> definition with Buckminster?
The simplest way is probably to let Buckminster create the target
platform using a normal resolve/materialize based on the target feature.
That way, the TP will contain everything that is needed and you won't
even need the target platform definition.
If you for some reason have to use the target definition, then
Buckminster must be able to find the missing pieces somewhere and
complement the TP. You can achieve this by adding an empty directory
container to the TP and then run a resolve/materialize on the target
feature. Buckminster will then use what's already in the TP and add
what's missing to the added container.
- thomas
Re: create a site.p2 from the target platform [message #970758 is a reply to message #970718] |
Sun, 04 November 2012 09:10   |
On 11/04/2012 09:26 AM, Thomas Hallgren wrote:
> Hi Lorenzo,
>> complains about
>> Buckminster
Hi Thomas
Do you mean to have a TP defined through a cspec, cquery and rmap
instead of defining a .target file?
or something else?
thanks in advance
Lorenzo
> - thomas
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: create a site.p2 from the target platform [message #972157 is a reply to message #971893] |
Mon, 05 November 2012 11:53   |
On 11/05/2012 08:32 AM, Thomas Hallgren wrote:
> On 2012-11-04 20:06, Lorenzo Bettini wrote:
>> Probably I understood what you meant... I shared an example here
>> https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster
> You did indeed. Great example!
Thanks!
I have a small problem when I try to build the p2 with Jenkins (I don't
have these problems when building in the IDE): although the platform is
resolved correctly with
resolve 'bucky.example.rcpemf.target/target-platform.cquery'
I get these errors when I try to resolve the target.site feature:
ERROR [0002] : No suitable provider for component
org.eclipse.equinox.launcher.gtk.linux.ppc64:osgi.bundle was found in
resourceMap
file:/usr/share/tomcat6/.jenkins/workspace/Buckminster-Target-p2/bucky.example.rcpemf.target/project.rmap
ERROR [0002] : Unable to find a searchPath for
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle was found in
resourceMap
where project.rmap is simply
<rm:rmap xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
<rm:property key="projects.location" value="${workspace.root}"/>
<rm:locator pattern="^bucky.example.rcpemf(?:\..+)?$"
searchPathRef="project"/>
<rm:searchPath name="project">
<rm:provider
componentTypes="eclipse.feature,osgi.bundle,buckminster"
readerType="local" mutable="false">
<rm:property key="buckminster.mutable" value="false"/>
<rm:uri format="{0}/{1}">
<bc:propertyRef key="projects.location"/>
<bc:propertyRef key="buckminster.component"/>
</rm:uri>
</rm:provider>
</rm:searchPath>
</rm:rmap>
the problems are due to the equinox.launcher fragments (I think they are
fragments)...
these fragments are included in the target.site/feature.xml
they are in the target platform, so why can't they be resolved?
I probably remove these fragments from the feature.xml, but I was
wondering why they cannot be resolved...
thanks in advance
Lorenzo
Re: create a site.p2 from the target platform [message #972213 is a reply to message #972157] |
Mon, 05 November 2012 12:48   |
> fragments)...
Not sure why this happens. Do you create the original TP from Juno or
from the Eclipse platfrom repository? I ask because IIRC some of the
launcher fragments are not present in Juno.
- thomas
Re: create a site.p2 from the target platform [message #972242 is a reply to message #972213] |
Mon, 05 November 2012 13:15   |
>> fragments)...
Hi Thomas
I'm using
http://download.eclipse.org/releases/juno
(see
https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster/blob/master/bucky.example.rcpemf.target/target-platform.rmap)
however, the strange thing is that in the target platform generated by
the jenkins job the fragments are there, e.g.,
ls
..buckminster/tp/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20120522-1813/META-INF/
eclipse.inf ECLIPSE_.RSA ECLIPSE_.SF MANIFEST.MF
but they cannot be resolved when performing site.p2 on the feature.xml...
most of all, I'm experiencing another critical problem:
I was using the cquery, rmap mechanism for defining the target platform
because, from what I understand, it allows me to have a target for
multiple environments, and to have automatically all the required
software installed (which is something that with a .target file
definition cannot co-exist).
In the IDE this works! But in Jenkins the target platform resolution
with the .cquery does not contain required software!
For instance, emf.sdk seems to require (among the others) org.apache.ant
and org.eclipse.jdt.annotation (there are only few of them). In the IDE
when I run the materialization these additional plugins are
materialized... in Jenkins they are not :(
In the IDE, I created an empty target platform manually that contains
one single and empty directory. Set this target platform active.
A subsequent resolution/materialization will use that platform, in order
to avoid the fact that "An automatically created target platform is
based on the configuration of the currently running Eclipse instance."
So now I'm kind of lost... headless target resolution behaves differently?
In Jenkins I'm performing target platform resolution as follows
is that correct?
thanks in advance
Lorenzo
Re: create a site.p2 from the target platform [message #972325 is a reply to message #972242] |
Mon, 05 November 2012 14:33   |
Peter Nehrer Messages: 241 Registered: July 2009 |
FWIW -- I run into a similar issue when building off of Juno. I believe
the missing launcher fragments (for some odd architectures like ppc) can
be found in http://download.eclipse.org/eclipse/updates/4.2. These
problems go away when I add that to my rmap file after Juno.
>>> fragments)...
> Hi Thomas
> I'm using
> (see
> ls
> is that correct?
> thanks in advance
> Lorenzo
Re: create a site.p2 from the target platform [message #972330 is a reply to message #972325] |
Mon, 05 November 2012 14:38   |
Thanks Peter, could you please share the rmap?
However, my problem might not be related to this, since in the IDE it
works, and, as I said, that fragments seem to be in the generated target
platform...
cheers
Lorenzo
>>>> are
>>>> fragments)...
>> Hi Thomas
>> I'm using
>> (see
>> ls
>> differently?
>> is that correct?
>> thanks in advance
>> Lorenzo
Re: create a site.p2 from the target platform [message #972737 is a reply to message #972579] |
Mon, 05 November 2012 21:33   |
Hi Andrea
don't worry: I consider myself a bucky newbie as well :)
On 11/05/2012 07:41 PM, Andrea Richiardi wrote:
> I am a newbie, so I might say something vrey wrong, but, do you have the
> delta pack in your materialized target?
the delta pack is not needed anymore from what I understand, as long as
you have a target platform with launchers for all environments...
> Because it seems it cannot find
> org.eclipse.equinox.launcher.gtk.linux.ppc64:osgi.bundle (among others I
> guess),
> that is part of the linux launcher. Is your IDE a linux ide as well?
if you see my previous post: in the IDE it all works fine since the
target platform materialization materializes all the launchers...
in Jenkins: it is exactly as in the IDE: the target platform
materialization materializes all the launchers, but then, when resolving
the feature.xml, which includes all the fragments for launchers, it is
not able to find the fragment bundles, even though they are in the
target platform... that's why it is strange...
in Jenkins it cannot find ANY launcher fragment... even though they're
all in the materialized target platform...
cheers
Lorenzo
Re: create a site.p2 from the target platform [message #973621 is a reply to message #972737] |
Tue, 06 November 2012 13:37   |
Do you by any chance have some setting for target.os, target.ws, and
target.arch in your IDE preferences? Buckminster will look at
"Preferences" -> "Run/Debug" -> "String Substitution".
Are you running Buckminster twice? Once to materialize the target
platform and then again to build using that platform? Or is it all in
one go? I.e. are you running using a Buckminster script file or are you
invoking Buckminster several times from Jenkins?
- thomas
Re: create a site.p2 from the target platform [message #973711 is a reply to message #972330] |
Tue, 06 November 2012 15:06   |
The relevant parts are:
<rm:locator searchPathRef="juno" failOnError="false"/>
<rm:locator searchPathRef="eclipse"/>
<rm:searchPath name="juno">
<rm:provider componentTypes="osgi.bundle,eclipse.feature"
readerType="p2">
<rm:uri format="http://download.eclipse.org/releases/juno"/>
</rm:provider>
</rm:searchPath>
<rm:searchPath name="eclipse">
readerType="p2">
<rm:uri format="http://download.eclipse.org/eclipse/updates/4.2"/>
</rm:provider>
</rm:searchPath>
> platform...
> cheers
> Lorenzo
>>>>> are
>>>>> fragments)...
>>> Hi Thomas
>>> I'm using
>>> (see
>>> ls
>>> differently?
>>> is that correct?
>>> thanks in advance
>>> Lorenzo
Re: create a site.p2 from the target platform [message #973940 is a reply to message #973621] |
Tue, 06 November 2012 18:45   |
I think I found my main (stupid) mistake in headless (Jenkins)
build scenario:
I was materializing (through a cquery) the target platform (which is in
a separate project), and then I was performing site.p2 on the
target.site feature (which is another project). The target.site feature
was correctly bound to the workspace (through the rmap) but it had not
been actually resolved/materialized (in the IDE I didn't need this step
of course) :)
if I materialize also the target.site feature (with another cquery)
everything works :) (modulo materializing and performing into two
Jenkins build step, otherwise you get the problem described here
http://www.eclipse.org/forums/index.php/m/767528/ for a particular
conflicting bundle).
I've updated
https://github.com/LorenzoBettini/Target_to_p2_with_Buckminster where I
also have another feature (target.mirror.site) where besides all the
bundles I include also the features of the target platform, so that I
end up with a site.p2 with all the IU of the target platform.
Stay tuned for a blog post where I'll try to describe all of this.
Bucky rocks! :)
cheers
Lorenzo
> - thomas
Re: create a site.p2 from the target platform [message #975324 is a reply to message #973963] |
Wed, 07 November 2012 19:49   |
On 11/06/2012 08:11 PM, Andrea Richiardi wrote:
> Nicely done!
> But, a newbie question:
> If my feature (plugin) has dependencies, these dependencies are found
> but they have dependencies themselves.
> Where are those taken from? The rmap? The TP? Do I have to materialize
> them in order to build the first plugin?
> My guess would be I don't, but I keep having errors about CSpec missing
> even if the plugin is actually in the right place and I am getting
> confused :)
Are you using the IDE or headlessly?
From what I know, you must materialize the TP and then you have to
materialize the main plugin (usually this is the main feature for your
project) so that all its dependencies are also materialized, using the
materialize TP and possibly by using the rmap (if it needs further
dependencies).
see also this brand new post :)
http://www.lorenzobettini.it/2012/11/materializing-and-provisioning-your-target-platform-as-local-p2-site-with-buckminster/
cheers
Lorenzo
Re: create a site.p2 from the target platform [message #985285 is a reply to message #984679] |
Thu, 15 November 2012 09:23   |
On 2012-11-14 23:24, Andrea Richiardi wrote:
> Another quick question, where is the headless buckminster materializing
> the tp?
Buckminster will materialize into the currently active TP. Unless you
specify what TP that will be, it will be a copy of the Runtime TP with
an additional folder that resides under the .buckminster project.
I'd recommend that you do the following to control the TP in you IDE.
1. Create a general project named TP.
2. Create a new PDE target platform (under pde preferences) named TP
where you add one location of type Directory. This directory should be
${workspace_loc:TP} (i.e. the project you just created).
3. Ensure that this new target platform is active.
Now run your resolve/materialize. Buckminster will populate the new TP.
From the command line you can use:
addtargetplatform -N TP -A <path to a directory>
to add an active target platform.
HTH,
- thomas
> Because in the log I see:
> Processing changes in target platform locations...
> INFO: Resetting target platform Buckminster Default TP
> Done processing changes in target platform locations
> Project com.test.ui now has dynamic dependencies to com.test.ui
> INFO: Import complete.
> Doing full workspace refresh
> Waiting for jobs to end
> But I can't, for example run:
> buckminster perform com.test.ui#whatever
> Receiving:
> No component named com.test.ui is known to Buckminster
> Why???
Re: create a site.p2 from the target platform [message #986267 is a reply to message #986246] |
Mon, 19 November 2012 16:43   |
Andrea Richiardi Messages: 64 Registered: August 2012 |
Member |
Ok, now, even in the IDE I receive:
ERROR: org.eclipse.core.runtime.CoreException: C:\eclipse\configuration\org.eclipse.osgi\bundles\302\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:214: C:\Users\arichiardi\Desktop\{fs:action.requirements} does not exist.
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTargetException(AntRunner.java:167)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:322)
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(AntActor.java:254)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(AbstractActor.java:195)
at org.eclipse.buckminster.core.internal.actor.PerformManager$DirectActionInvocation.execute(PerformManager.java:143)
at org.eclipse.buckminster.core.internal.actor.PerformManager.internalPerform(PerformManager.java:454)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:293)
at org.eclipse.buckminster.core.internal.actor.PerformManager.perform(PerformManager.java:305)
at org.eclipse.buckminster.ui.InvokeActionJob.runInWorkspace(InvokeActionJob.java:67)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: C:\eclipse\configuration\org.eclipse.osgi\bundles\302\2\.cp\org\eclipse\buckminster\pde\antscripts\build.xml:214: C:\Users\arichiardi\Desktop\{fs:action.requirements} does not exist.
at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
at org.apache.tools.ant.taskdefs.Copy.execute(Copy.java:489)
at org.eclipse.buckminster.ant.taskdefs.Copy.execute(Copy.java:42)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:392)
at org.apache.tools.ant.Target.performTasks(Target.java:413)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.executeTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:672)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(InternalAntRunner.java:498)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:318)
... 9 more
[Updated on: Mon, 19 November 2012 17:19] Report message to a moderator
Current Time: Mon Jan 18 02:19:03 GMT 2021
Powered by FUDForum. Page generated in 0.03573 seconds
