Re: Lost in documentation (complete post) [message #138148 is a reply to message #138127] |
Mon, 10 November 2008 15:53 |
Eugene Chan Messages: 287 Registered: July 2009 |
Hi. Chris,
Thanks so much for your interest on TPTP.
There is a more updated documentation/getting start page on TPTP wiki:
http://wiki.eclipse.org/Profiling_with_TPTP_-_plug-in_develo pment
Note the in the latest JVMTI profiler supported by JVM version 1.5+,
analysis types are mutually exclusive and only a single analysis type is
available per each profiling session.
Eugene
"Chris DiGiano" <digi@computer.org> wrote in message
news:d7af28af831183fbadec24b28845c2cf$1@www.eclipse.org...
> My first post was sent prematurely. Here's the complete message...
> I cannot seem to get a basic profiling example to work with TPTP 4.5.1 and
> Eclipse Ganymede. I looked all over the TPTP site for the latest docs, but
> could only find this tutorial:
> http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html
> (which I suspect was written for Eclipse 3.2)
> The tutorial has the developer doing both memory and time analysis, but in
> the profiling configuration for 4.5 I could only select one or the other.
> Furthermore, the tutorial has you filter some events, but I did not see
> how to do this with the latest plug-in.
> Eventually, I was able to start time monitoring the CarModel, but I could
> not see how to view method-level information. There was no "M" icon as
> described in the tutorial. So, in the end I could not find any way to
> actually via the profiling log.
> Is there more up-to-date "getting started" documentation? As much as I'm
> excited about using TPTP, my impression is that the TPTP site is in need
> of a refresh.
> Any pointers would be appreciated!
> Chris DiGiano
Re: Lost in documentation (complete post) [message #139267 is a reply to message #138148] |
Sat, 03 January 2009 09:16 |
Originally posted by: jesus.m.salvo.gmail.com
On Mon, 10 Nov 2008 10:53:14 -0500, Eugene Chan wrote:
> Hi. Chris,
> Thanks so much for your interest on TPTP. There is a more updated
> Eugene
I was going to ask the same question as Chris with regards to not being
able to do more than one type of analysis ( memory + execution +
thread ). I was hoping that TPTP would do this, just like as is currently
possible with JProfiler. Would be great so that you just profile the Java
application only once, specially if what you are profiling runs over a
long period of time ( e.g. half of the working day to profile an
overnight batch job ). Will this be a future enhancement ?
Furthermore, I am also confused with the "Guide to TPTP BIRT Reports" URL:
http://www.eclipse.org/tptp/home/documents/process/developme nt/Guide-to-
TPTP-BIRT-Reports.html#2.1
Since it is written for TPTP 4.5 ( I followed the link from TPTP
Documentation -> 4.5 ), I presume I would be able to generate those pie,
line chats into HTML.
However, on Eclipse 3.4.1, after I did a memory analysis, the context
menu says:
1) New Report ( instead of Report ) ... no big deal there
2) HTML Trace Report ( instead of HTML trace report (BIRT) )
3) I only get one HTML file, and no charts. The output of the HTML file
is the same as the Memory Statistics / Object Allocations tab, but nothing more.
What am I missing ?
I have the following installed ( list limited to TPTP / BIRT / GEF / DATATOOLS ):
org.eclipse.birt (2.3.1.v20080630-7N7Y7AAYdlIXLgz-SLsyMQ21x2fI) "Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.3.1.v20080630-7_7D4_toGwkNz0b4pt0sBQJZunS2) "BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.3.1.v20080630-2207w31191812) "BIRT Chart Context-sensitive Help"
org.eclipse.birt.chart.runtime (2.3.1.v20080630-7X8n6EMNbos-rAPIYtmR1) "BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.3.1.v20080630-2207w31191_1_) "BIRT Context-sensitive Help"
org.eclipse.birt.doc (2.3.1.v20080630-2207w31191_34b) "BIRT Documentation"
org.eclipse.birt.example (2.3.1.v20080630-7D7J5CYQCD4D2If) "BIRT Example"
org.eclipse.birt.report.designer (2.3.1.v20080630-7X7n7FECLqlyX1jw48bOyH4E0ha5) "BIRT Report Designer"
org.eclipse.birt.report.runtime (2.3.1.v200807162-7k8E7KEMVkywAg5R0ebrWS) "BIRT Report Runtime"
org.eclipse.gef (3.4.1.v20080806) "Graphical Editing Framework GEF" [Starting]
org.eclipse.gef.doc.isv (3.4.1.v20080806) "Graphical Editing Framework GEF Documentation" [Starting]
org.eclipse.gef.examples.ui.pde (3.4.0.v20080226) "Graphical Editing Framework Example Plug-ins" [Starting]
org.eclipse.gef.source (3.4.1.v20080806-67718083A56B4H2A3213573) "Graphical Editing Framework GEF Developer Resources" [Resolved]
org.eclipse.datatools.common.doc.user (1.6.1.v20080828133713) "Data Tools Platform Tutorial Documentation" [Resolved]
org.eclipse.datatools.connectivity (1.1.1.v200809180120) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.1.v200807150030) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.0.v200805152355) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.v200805152355) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.0.v200805152355) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.6.1.v20080828133713) "Data Tools Platform Connectivity Documentation" [Resolved]
org.eclipse.datatools.connectivity.doc.user.contexts (1.6.1.v20080828133713) "Data Tools Platform Connectivity Documentation for context-sensitive help" [Resolved]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.7.v200808051050) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.7.v200808261835) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.7.v200808130628) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.v200805152355) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.3.v200809180120) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.1.v200808140022) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.1.v200808300421) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.2.v200809150616) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.1.v200807230727) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.templates (1.0.0.v200805152355) "DTP Connectivity Templates Plug-in" [Starting]
org.eclipse.datatools.doc.isv (1.6.0.200806091108) "Data Tools Documentation Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools Platform User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v200805152355) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.v200805152355) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n (1.0.0.v200806100223) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.0.v200805160737) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.v200805152355) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.0.v200805152355) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.v200805152355) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n (1.0.0.v200805152355) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.0.v200805160737) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.1.v200807170829) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200805152355) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.1.v200808261158) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.v200805170742) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.1.v200808211640) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.1.v200808271112) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.1.v200808261409) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.1.v200808130628) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.1.v200808021450) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.0.v200805152355) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200805310538) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200807010411) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200808221518) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.6.1.v200807021300) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.v200808020150) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.v200805152355) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200807251820) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200808280228) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sdk.feature.source (1.6.1.v200809191145) "Eclipse Datatools Source" [Resolved]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200807211830) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.v200808260630) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.1.0.v200808260630) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200808140643) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.6.1.v20080828133713) "Data Tools Platform SQL Dev Tools Documentation" [Resolved]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200808271350) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200808080530) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200808140615) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v200808140615) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200807211830) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200808271350) "Eclipse Data Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200808140615) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200808271350) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200808271350) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200808271350) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.v200808300730) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615) "Eclipse Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.tptp.examples (4.5.0.v200803191201-7B7_CE87CDJE2D9EFFDD7CF_4) "TPTP Examples"
org.eclipse.tptp.monitoring (4.4.100.v200805120832-7d7OEINE8McIJXIvZtNAa2) "TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user (4.4.0.v200804180100-784CF8s733I3C684B7A) "TPTP Monitoring Project Documentation"
org.eclipse.tptp.monitoring.examples (4.3.200.v200803201123-44-7w311916231943) "User examples for the TPTP Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation (4.3.100.v200805120832-7B79Ag9oA55S5L8H7796) "TPTP Instrumentation Monitoring "
org.eclipse.tptp.monitoring.la.core (4.4.100.v200806121215-7B78CE9oA55S5GAA8MAM) "Monitoring Log Analyzer Core backward compatibility"
org.eclipse.tptp.monitoring.lta.profile.server (4.5.0.v200805132041-7B7D-9oA55S5J_M7C_B) "TPTP Profile On Server Logging Utility"
org.eclipse.tptp.monitoring.managedagent (4.4.100.v200805120832-7F7DCF_kE77c7MBH7H_9) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents (4.4.100.v200805120832-4307w311916231943) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx (4.4.1.v200802291616-3-27w3119133_2562) "MX4J"
org.eclipse.tptp.monitoring.profile.server (4.2.200.v200805271330-7B78Dp9oA55S5GAA8MAM) "TPTP Profile On Server Logging Utility backward compatibility"
org.eclipse.tptp.monitoring.report.birt (4.5.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence and Reporting Tools (BIRT) Log Reports"
org.eclipse.tptp.platform.analysis (4.4.100.v200806050100-7F7_EAU_kE77c7U7Q7A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java (4.4.200.v200806050100-7877_78s733I3E3C3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine (4.3.200.v200806050100-784Ag8s733I3C5_4_59) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.5.1.v200807310709-8Z8DEpNELRXmprpJQYrC5n) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user (4.3.300.v200807310709-7B6EAU9oA55S5LAD6D6J) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.3.300.v200807310709-7B77EAU8_JKQVTMuLIBdBREPCJ7K) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.examples (4.3.200.v200806121215-42_77w311916231943) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui (4.2.100.v200805120832-78778Y8s733I3D684549) "TPTP Instrumentation UI Core"
org.eclipse.tptp.platform.integration.pde (4.4.1.v200806121215-4307w311916231943) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti (4.3.200.v200807310709-7877Ag8s733I3H684574) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core (4.3.200.v200806121215-42_77w311916342227) "Log Analysis Core backward compatibility"
org.eclipse.tptp.platform.lta (4.3.200.v200805201414-783CF8s733I3B674G8A) "TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.3.300.v200807310709-7F5EII_kE77c7WCG7UCJ) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user (4.3.200.v200802291616-41_77w311916231943) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server (4.3.200.v200807310709-7F79E8P_kE77c7XDH7T_Q) "TPTP Profile on Server"
org.eclipse.tptp.platform.report (4.2.200.v200805120832-7B5Dq9oA55S5K9B7F_H) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt (4.3.300.v200807310709-7877_88s733I3F4C3B65) "TPTP Business Intelligence and Reporting Tools (BIRT) Reporting Infrastructure"
org.eclipse.tptp.platform.samples (4.3.200.v200805120832-7B4E9x9oA55S5G9H5LA9) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.report.birt (4.5.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence and Reporting Tools (BIRT) Statistical Reports"
org.eclipse.tptp.platform.statistical.ui (4.1.400.v200805120832-783Ag8s733I3_6A3B65) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.3.300.v200807310709-7J7EEC5AgI99m9cHO_QFK) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.301.v200807310709-7J7DEC6AgI99m9kDWAWHP) "TPTP Test Framework"
org.eclipse.tptp.test.doc.user (4.3.300.v200807310709-42_77w31191842181_) "TPTP Test Tools User Documentation"
org.eclipse.tptp.test.recorders.url (4.5.1.v200807310709-787908s733I3E763H6D) "TPTP URL Recorder"
org.eclipse.tptp.test.report.birt (4.4.1.v200807310709-7B7D09oA55S5M_D6D6J) "TPTP Business Intelligence and Reporting Tools (BIRT) Test Reports"
org.eclipse.tptp.test.runtime (4.3.300.v200807310709-7F7_EDd7SndHmrSPQ2rBXou4z0FT) "TPTP Test Framework"
org.eclipse.tptp.test.samples (4.2.100.v200805120832-418Y7w311916421211) "TPTP Test Framework and Tools Samples"
org.eclipse.tptp.test.tools (4.3.300.v200807310709-7J7JAj_5cMYjYU0bJowWlJUSVSG) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit (4.5.1.v200807310709-7F7GCG_kE77c7bAO8MBF) "TPTP JUnit Plug-in Test Tools"
org.eclipse.tptp.trace (4.2.200.v200807310709-781EC58s733I3E763H6D) "TPTP Trace"
org.eclipse.tptp.trace.arm (4.2.100.v200805120832-782_78s733I3_6D3B65) "TPTP ARM Monitoring "
org.eclipse.tptp.trace.arm.ui (4.3.100.v200805120832-7858Z8s733I3D684549) "Instrument ARM UI"
org.eclipse.tptp.trace.jvmti (4.2.200.v200807310709-43_77w31191842181_) "TPTP Trace JVMTI Client"
org.eclipse.tptp.trace.report.birt (4.5.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence and Reporting Tools (BIRT) Trace Reports"
FUDForum. Page generated in 0.03327 seconds
