Mapping the JDBC data type NUMERIC to a Java data type in Scout [message #968564] |
Fri, 02 November 2012 15:01 |
Hello
When a database query is executed from Scout, the appropriate SQL style is used to map the resulting data from JDBC data types to Java data types.
In my example, I have an Oracle database with a column of type NUMBER(15,5). Apparently, the JDBC data type is Types.NUMERIC (seems correct, see [1]), which is mapped by Scout's AbstractSqlStyle to either java.lang.Double or java.lang.Long (depending on the number's scale)! This may result in an Object[][] that does not have equal datatypes on all rows! Example:
- Value in database: 1.5
JDBC-Type: Types.NUMERIC
Mapped Java-Type: java.lang.Double
- Value in database: 1.0
Mapped Java-Type: java.lang.Long
Relevant code locations:
* org.eclipse.scout.rt.server.services.common.jdbc.internal.exec.StatementProcessor.processResultRow(ResultSet)
* org.eclipse.scout.rt.server.services.common.jdbc.style.AbstractSqlStyle.readBind(ResultSet, ResultSetMetaData, int, int)
This seems wrong to me. In the database all rows have an identical data type for a specific column, so I would assume that the resulting Java data types are equal, too. Mixing data types can lead to problems, e.g. when I want to use the MatrixUtility to sort an Object[][].
Can you explain the reasons for the described behaviour to me?
Kind regards,
Beat
[1] http://docs.oracle.com/javase/1.5.0/docs/guide/jdbc/getstart/mapping.html -> chapter 8.3.1
[Updated on: Fri, 02 November 2012 15:04] Report message to a moderator
FUDForum. Page generated in 0.02768 seconds
