Home » Archived » Visual Editor (VE) » After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin.
After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137903] Wed, 06 June 2007 17:33 Go to next message
I installed VE via the Callisto update site, when I try to create a new
Visual Class and enter the Class Name in the form, a message pops up at
the top of the form saying:
I cannot continue with creating the class then. Anyone had this before?
Felix
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137915 is a reply to message #137903] Wed, 06 June 2007 19:07 Go to previous messageGo to next message
This says you are trying to create a RCP class or your project is a
plugin project. If your project is a plugin project, then you need to
add org.eclipse.ui as a required plugin for the plugin. That is where
you will be getting SWT from. Without this then SWT is not available so
it can't create an SWT class.
Felix Dorner wrote:
> Felix
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137925 is a reply to message #137915] Thu, 07 June 2007 03:33 Go to previous messageGo to next message
Yes, actually it´s a plugin (EMF) project.. I forgot about that. Thank you.
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137937 is a reply to message #137915] Thu, 07 June 2007 03:42 Go to previous messageGo to next message
now I can create a Visual Class, however when the VE View says "Loading"
and Progress View says "Create Remote VM for Visual Editor for Java" I
get the following Error Message: Could not find the Main Class. Program
will Exit. And Later: Error trying to set new file into editor.
Anything aboout this?
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137948 is a reply to message #137937] Thu, 07 June 2007 03:50 Go to previous messageGo to next message
The error described below does not occur in a "Java Project"
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #137959 is a reply to message #137948] Thu, 07 June 2007 09:25 Go to previous message
That one's a toughie. Not sure. This probably means there was some
problem with the classpath and so certain required classes couldn't be
found.
See if there are any other errors like ClassDefNotFoundError in the .log.
>> "Loading" and Progress View says "Create Remote VM for Visual Editor
>> for Java" I get the following Error Message: Could not find the Main
>> Class. Program will Exit. And Later: Error trying to set new file into
>> editor.
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615321 is a reply to message #137903] Wed, 06 June 2007 19:07 Go to previous message
Felix Dorner wrote:
> Felix
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615323 is a reply to message #137915] Thu, 07 June 2007 03:33 Go to previous message
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615324 is a reply to message #137915] Thu, 07 June 2007 03:42 Go to previous message
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615326 is a reply to message #137937] Thu, 07 June 2007 03:50 Go to previous message
Re: After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin. [message #615328 is a reply to message #137948] Thu, 07 June 2007 09:25 Go to previous message
found.
>> editor.
Previous Topic:After Installation: Plugin org.eclipse.ui is required. Must be added as a dependent plugin.
Next Topic:VE missing from Eclipse
Current Time: Thu Jul 10 19:57:03 EDT 2025
Powered by FUDForum. Page generated in 0.05083 seconds
