JSP ERROR!!! [message #137797] |
Fri, 09 September 2005 14:57 |
Originally posted by: claudia_rego.hotmail.com
help please....
I'm using Building a simple EJB Application.
Everything it's ok except when i invoke the bean's method in jsp page:
HTTP Status 500 -
description - The server encountered an internal error () that prevented
it from fulfilling this request.
What the problem??
Thanks claudia
Re: JSP ERROR!!! [message #137831 is a reply to message #137810] |
Fri, 09 September 2005 15:12 |
In the web browser, i get:
type Exception report
message
description The server encountered an internal error () that prevented it
exception
org.apache.jasper.JasperException
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:370)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:81)
root cause
org.apache.jsp.testz_jsp._jspService(org.apache.jsp.testz_js p:59)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:322)
note The full stack trace of the root cause is available in the Apache
Tomcat/5.5.9 logs.
Re: JSP ERROR!!! [message #137865 is a reply to message #137831] |
Fri, 09 September 2005 17:26 |
> message
> exception
> root cause
> Tomcat/5.5.9 logs.
> Thanks
I assume you are using Jboss as EJB container, the latest version ? is
it supported by eclipse ?
hicham.
Re: JSP ERROR!!! [message #138281 is a reply to message #137865] |
Sun, 11 September 2005 21:42 |
Yes! You're right.
I'm using Eclipse 3.1 + WTP0.7 and JBoss4.0.2
Can you help me?
Have you followed this tutorial (Building a Simple EJB Application)?
Thanks Claudia
Re: JSP ERROR!!! [message #138420 is a reply to message #138281] |
Tue, 13 September 2005 11:35 |
Hello!
People I really need help...
Who accepted my project to make deploy in its machine?
Please
Claudia
Re: JSP ERROR!!! [message #138431 is a reply to message #137831] |
Tue, 13 September 2005 13:23 |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Claudia,
according to the error message there is a NullPointerException in your
JSP code.
Take a look at the java file which is generated from the jsp by jboss
(should be found somewhere in your jboss server, search for
"testz_jsp.java"). At line 59 of this file you should find the erranous
line. Please post this file here.
Best regards
Wolfgang
Claudia Rego wrote:
> root cause
Re: JSP ERROR!!! [message #138573 is a reply to message #138420] |
Tue, 13 September 2005 18:14 |
The code of zootest_jsp.java:
package org.apache.jsp;
import javax.servlet.*;
import javax.servlet.http.*;
import javax.servlet.jsp.*;
import java.util.*;
import javax.naming.*;
import javax.rmi.PortableRemoteObject;
import com.zoo.Tiger;
import com.zoo.TigerHome;
import com.zoo.TigerUtil;
public final class zootest_jsp extends
implements org.apache.jasper.runtime.JspSourceDependent {
private static java.util.Vector _jspx_dependants;
public java.util.List getDependants() {
return _jspx_dependants;
public void _jspService(HttpServletRequest request, HttpServletResponse
response)
throws java.io.IOException, ServletException {
JspFactory _jspxFactory = null;
PageContext pageContext = null;
HttpSession session = null;
ServletContext application = null;
ServletConfig config = null;
JspWriter out = null;
Object page = this;
JspWriter _jspx_out = null;
PageContext _jspx_page_context = null;
try {
_jspxFactory = JspFactory.getDefaultFactory();
response.setContentType("text/html; charset=ISO-8859-1");
pageContext = _jspxFactory.getPageContext(this, request, response,
null, true, 8192, true);
_jspx_page_context = pageContext;
application = pageContext.getServletContext();
config = pageContext.getServletConfig();
session = pageContext.getSession();
out = pageContext.getOut();
_jspx_out = out;
out.write(" \r\n");
out.write("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01
Transitional//EN\"> \r\n");
out.write("\r\n");
out.write("\r\n");
out.write("\r\n");
out.write("<html>\r\n");
out.write("<head>\r\n");
out.write("<title>Insert title here</title>\r\n");
out.write("</head>\r\n");
out.write("<body>\r\n");
Object obj = TigerUtil.getHome();
out.write(" \r\n");
out.write("\r\n");
out.write("</body>\r\n");
out.write("</html>\r\n");
} catch (Throwable t) {
if (!(t instanceof SkipPageException)){
out = _jspx_out;
if (out != null && out.getBufferSize() != 0)
out.clearBuffer();
if (_jspx_page_context != null)
_jspx_page_context.handlePageException(t);
} finally {
if (_jspxFactory != null)
_jspxFactory.releasePageContext(_jspx_page_context);
Re: JSP ERROR!!! [message #138734 is a reply to message #138573] |
Wed, 14 September 2005 18:24 |
softlogo Messages: 7 Registered: July 2009 |
I tried same thing and it seems like TigerHome (generated by XDoclet
when TigerBean is created) can't find "Tiger" bean, it actually throws a
Naming Exception. You can confirm that if you replace JSP code by some
thing like this
<html>
<head>
</head>
<body>
com.zoo.Tiger tiger = null;
try{
com.zoo.TigerHome home = com.zoo.TigerUtil.getHome();
tiger = home.create();
}catch(Exception e)
//it is never good to ignore exceptions
e.printStackTrace();
<b><%= tiger.roar() %></b>
</body>
</html>
> import java.util.*;
> response)
> Object page = this;
> try {
> _jspx_out = out;
> out.write(" \r\n");
> out.write("\r\n");
> out.write("\r\n");
> out.write("\r\n");
> out.write(" \r\n");
> out.write("\r\n");
> out = _jspx_out;
> out.clearBuffer();
> } finally {
> Thanks
Re: JSP ERROR!!! [message #138802 is a reply to message #138281] |
Wed, 14 September 2005 20:57 |
Originally posted by: pavery.us.ibm.com
Claudia Rego wrote:
> Yes! You're right.
> Can you help me?
> Thanks Claudia
I might be mistaken, but I think only JBoss 3.2.3 is supported by WTP...
-phil
Re: JSP ERROR!!! [message #138886 is a reply to message #137797] |
Thu, 15 September 2005 11:22 |
After many days thought I have found the problem. I think...
AS i said, i am following the WTP Tutorial - Building a Simple EJB
Application.
I had an error when i run the JSP page in the server. Using the code shown
in tutorial:
<html>
<head>
</head>
<body>
try{
}catch(Exception exception)
</body>
I get an Exception:
16:36:56,046 ERROR [[jsp]] Servlet.service() for servlet jsp threw
exception
So i went step by step. My JSP page:
<html>
<head>
</head>
<body>
System.out.println("Step1");
System.out.println("Step2");
</body>
I find that Step1 is done perfectly but Step 2 NO!! Because in
TigerUtil.getHome() there is the problem in the line:
javax.rmi.PortableRemoteObject.narrow(objRef, narrowTo);
The exception generated is:
java.lang.ClassCastException
After search in all forums and the all www :) I find:
http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=4730878
"javax.rmi.PortableRemoteObject.narrow(...) casts the returned result to
the java.rmi.Remote interface...This behavior is contradiciting the spec
of javax.rmi.PortableRemoteObject.narrow(...): "Checks to ensure that an
object of a remote or abstract interface type can be cast to a desired
type"
Since the abstract interfaces do not implement Remote, this code will
break for customers using abstract interfaces in their application. This
code results in ClassCastException..." from Sun
What you find? I am correct?
If yes, as to exceed the problem?
Please, send me feedback
Thnkxx
Cláudia
Re: JSP ERROR!!! [message #138898 is a reply to message #138886] |
Thu, 15 September 2005 11:33 |
Hi Claudia,
what's your Java version ? I used this Util class with 1.4.2_09 and it
worked fine. Is there a chance the the JNDI names for local/remote
interfaces got mixed up ?
Post your complete ear project to make it easier to find the problem
(use "export to EAR file" with option "export source files").
Best regards
Wolfgang
> Application.
> shown in tutorial:
> <html>
> <head>
> </head>
> <body>
> try{
> </body>
> I get an Exception:
> exception java.lang.NullPointerException
> <html>
> <head>
> </head>
> <body>
> <% com.zoo.TigerHome home = com.zoo.TigerUtil.getHome();
> </body>
> type"
> Thnkxx
> Cláudia
Re: JSP ERROR!!! [message #138909 is a reply to message #138802] |
Thu, 15 September 2005 11:35 |
Hi Phil,
search this NG, there is a plugin for JBoss 4.0 which works fine.
Best regards
Wolfgang
phil avery wrote:
> Claudia Rego wrote:
>> Yes! You're right.
>> Can you help me?
>> Thanks Claudia
> -phil
Re: JSP ERROR!!! [message #138944 is a reply to message #138898] |
Thu, 15 September 2005 13:43 |
Wolfgang Knauf wrote:
> Hi Claudia,
I'm using J2EE 1.4 SDK 2005Q2 UR2
I don't know I to do it. It's some kind of attach??
Thankxx
Cláudia
Re: JSP ERROR!!! [message #139173 is a reply to message #138944] |
Fri, 16 September 2005 11:56 |
Hi Claudia,
You mean how to attach the file to the newsgroup post ? This depends on
your newsreader.
Best regards
Wolfgang
Re: JSP ERROR!!! - SOLUTION [message #139438 is a reply to message #139173] |
Mon, 19 September 2005 11:26 |
People i find what was wrong!!!
The version of the EJB and Web Module. When i tried EJB 2.0 and Web Module
2.3 it WORKS!!!
A special thanks to Haroon!
Thankx to all you spend time with my problme.
Claudia
FUDForum. Page generated in 0.04251 seconds
