Re: Net4j Oracle DB Adaptor [message #973998 is a reply to message #973597] |
Tue, 06 November 2012 19:44 |
Andrew Whelan Messages: 71 Registered: October 2012 Location: Syracuse NY |
Member |
Yes that works.
However now I am getting the "Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs" exception that I've seen reported by other users. However the "caused by" exception. In this case the "Caused by" exception is java.sql.SQLException: ORA-00936: missing expression.
I believe the reason this is getting flagged is because "size" is an oracle keyword. Its important to note that I don't see any tables getting created. The user "repo1" has the correct permissions. I can create, drop, and select tables using SQLPLUS and also in a little java application that I am running from the same Eclipse IDE.
Does anyone have any ideas?
Following is the complete stack trace:
!ENTRY org.eclipse.net4j.util 4 0 2012-11-06 14:39:23.342
!MESSAGE Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
!STACK 0
org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:447)
at org.eclipse.net4j.spi.db.DBAdapter.createTable(DBAdapter.java:146)
at org.eclipse.net4j.spi.db.DBAdapter.createTables(DBAdapter.java:111)
at org.eclipse.net4j.spi.db.DBSchema.create(DBSchema.java:118)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:531)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1846)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:208)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.sql.SQLException: ORA-00936: missing expression
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:331)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:288)
at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:743)
at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:207)
at oracle.jdbc.driver.T4CStatement.executeForDescribe(T4CStatement.java:790)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1038)
at oracle.jdbc.driver.T4CStatement.executeMaybeDescribe(T4CStatement.java:830)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1133)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1273)
at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:428)
... 18 more
... 18 more
!ENTRY org.eclipse.equinox.app 4 0 2012-11-06 14:39:23.343
!STACK 0
... 18 more
FUDForum. Page generated in 1.12142 seconds
