Home » Archived » Visual Editor (VE) » Problems with installing the Visual Editor
Problems with installing the Visual Editor [message #137606] Wed, 09 May 2007 10:25 Go to next message
Originally posted by: markus43534.yahoo.de
I have problems with installing the Visual Editor.
I'm using Eclipse 3.2.
I installed teh VE according to this FAQ:
http://www.eclipse.org/vep/WebContent/faq.html#install_howto
In the installation process I got no error messages. But after
installing there is no option for creating a Visual Class in the tree
menu of the Package Explorer when I right-click on a project and then
select "new".
Can anyone help me with this problem, please.
Markus
Re: Problems with installing the Visual Editor [message #137618 is a reply to message #137606] Wed, 09 May 2007 13:11 Go to previous messageGo to next message
Those instructions are basically obsolete.
Instead:
1) Install the Eclipse 3.2 SDK (it must be the SDK).
2) Use Help->Manage Configuration->Find and Install new features.
3) Select the Callisto site, hit next.
4) When you get to the listing of features, expand the EMF feature,
just expand it, that's all.
5) Expand the VE feature, select the VE feature desired and hit
the "Add Required Features" button.
6) Then hit Install.
Markus Schneider wrote:
> Hello,
> select "new".
> Markus
Rich Kulp
Re: Problems with installing the Visual Editor [message #137653 is a reply to message #137618] Tue, 15 May 2007 08:43 Go to previous messageGo to next message
Many thanks for the instructins. VE is working now.
Re: Problems with installing the Visual Editor [message #137664 is a reply to message #137653] Tue, 15 May 2007 08:46 Go to previous messageGo to next message
another question: is there any way to make a visual class out of an
existing JFrame extending class.
Re: Problems with installing the Visual Editor [message #137675 is a reply to message #137664] Tue, 15 May 2007 14:14 Go to previous messageGo to next message
You can try just opening it with the Visual Editor (i.e. Open
with->Visual Editor), but unless it is written in a pattern the VE
understands it may not work correctly.
Rich Kulp
Re: Problems with installing the Visual Editor [message #137858 is a reply to message #137618] Wed, 30 May 2007 14:24 Go to previous messageGo to next message
Originally posted by: enrique.garcia.atosresearch.eu
> Instead:
>> Hello,
>> select "new".
>> Markus
I have followed this instructions and I cannot see Create New Virtual
Class option despite I have installed Eclipse Modeling Framework,
Graphical Modeling Framework...
Any suggestions please?
Kike
Re: Problems with installing the Visual Editor [message #137983 is a reply to message #137858] Thu, 07 June 2007 23:07 Go to previous message
Originally posted by: softwaredev.hughes.net
Kike wrote:
>> Instead:
>>> Hello,
>>> select "new".
>>> Markus
> Cheers,
> Kike
This doesn't work for me either. Now the 'Finish' button (in Updates)
remains greyed out.
Dave
Re: Problems with installing the Visual Editor [message #615223 is a reply to message #137606] Wed, 09 May 2007 13:11 Go to previous message
Instead:
> Hello,
> select "new".
> Markus
Rich Kulp
Re: Problems with installing the Visual Editor [message #615233 is a reply to message #137618] Tue, 15 May 2007 08:43 Go to previous message
Re: Problems with installing the Visual Editor [message #615237 is a reply to message #137653] Tue, 15 May 2007 08:46 Go to previous message
Re: Problems with installing the Visual Editor [message #615242 is a reply to message #137664] Tue, 15 May 2007 14:14 Go to previous message
Rich Kulp
Re: Problems with installing the Visual Editor [message #615308 is a reply to message #137618] Wed, 30 May 2007 14:24 Go to previous message
> Instead:
>> Hello,
>> select "new".
>> Markus
Kike
Re: Problems with installing the Visual Editor [message #615332 is a reply to message #137858] Thu, 07 June 2007 23:07 Go to previous message
David Williams is currently offline David WilliamsFriend
Kike wrote:
>> Instead:
>>> Hello,
>>> select "new".
>>> Markus
> Cheers,
> Kike
remains greyed out.
Dave
Previous Topic:VE missing from Eclipse
Next Topic:drag and drop with VE
Current Time: Tue Apr 16 18:29:00 GMT 2024
Powered by FUDForum. Page generated in 0.21972 seconds
