Problems with installing the Visual Editor [message #137606] |
Wed, 09 May 2007 10:25 |
Originally posted by: markus43534.yahoo.de
I have problems with installing the Visual Editor.
I'm using Eclipse 3.2.
I installed teh VE according to this FAQ:
http://www.eclipse.org/vep/WebContent/faq.html#install_howto
In the installation process I got no error messages. But after
installing there is no option for creating a Visual Class in the tree
menu of the Package Explorer when I right-click on a project and then
select "new".
Can anyone help me with this problem, please.
Markus
Re: Problems with installing the Visual Editor [message #137618 is a reply to message #137606] |
Wed, 09 May 2007 13:11 |
Those instructions are basically obsolete.
Instead:
1) Install the Eclipse 3.2 SDK (it must be the SDK).
2) Use Help->Manage Configuration->Find and Install new features.
3) Select the Callisto site, hit next.
4) When you get to the listing of features, expand the EMF feature,
just expand it, that's all.
5) Expand the VE feature, select the VE feature desired and hit
the "Add Required Features" button.
6) Then hit Install.
Markus Schneider wrote:
> Hello,
> select "new".
> Markus
Rich Kulp
Re: Problems with installing the Visual Editor [message #137675 is a reply to message #137664] |
Tue, 15 May 2007 14:14 |
You can try just opening it with the Visual Editor (i.e. Open
with->Visual Editor), but unless it is written in a pattern the VE
understands it may not work correctly.
> another question: is there any way to make a visual class out of an
> existing JFrame extending class.
Rich Kulp
Re: Problems with installing the Visual Editor [message #137858 is a reply to message #137618] |
Wed, 30 May 2007 14:24 |
Originally posted by: enrique.garcia.atosresearch.eu
> Instead:
>> Hello,
>> select "new".
>> Markus
I have followed this instructions and I cannot see Create New Virtual
Class option despite I have installed Eclipse Modeling Framework,
Graphical Modeling Framework...
Any suggestions please?
Kike
Re: Problems with installing the Visual Editor [message #137983 is a reply to message #137858] |
Thu, 07 June 2007 23:07 |
Originally posted by: softwaredev.hughes.net
Kike wrote:
>> Instead:
>>> Hello,
>>> select "new".
>>> Markus
> Cheers,
> Kike
This doesn't work for me either. Now the 'Finish' button (in Updates)
remains greyed out.
Dave
Re: Problems with installing the Visual Editor [message #615223 is a reply to message #137606] |
Instead:
> Hello,
> select "new".
> Markus
Rich Kulp
Re: Problems with installing the Visual Editor [message #615242 is a reply to message #137664] |
Rich Kulp
Re: Problems with installing the Visual Editor [message #615308 is a reply to message #137618] |
> Instead:
>> Hello,
>> select "new".
>> Markus
Kike
Re: Problems with installing the Visual Editor [message #615332 is a reply to message #137858] |
David Williams Messages: 176 Registered: July 2009 |
Kike wrote:
>> Instead:
>>> Hello,
>>> select "new".
>>> Markus
> Cheers,
> Kike
remains greyed out.
Dave
FUDForum. Page generated in 0.03533 seconds
