Home » Eclipse Projects » Remote Application Platform (RAP) » Path in Upload-Widget
Path in Upload-Widget [message #137446] Tue, 23 June 2009 18:00 Go to next message
rollo is currently offline rolloFriend
I have a little strange problem with the Upload-Widget when I'm using
the IE8.
When I choose the file "file.txt" via the browse button, then stands in
the Textfield "C:\fakepath\file.txt" as path.
The upload is still working, but where does this strange path comes from?
Roland
Re: Path in Upload-Widget [message #137571 is a reply to message #137446] Wed, 24 June 2009 11:06 Go to previous messageGo to next message
Stefan   is currently offline Stefan Friend
Hi Roland,
just tested it and have the same effect. Seems as if IE8 now also blocks
reading the local path of a uploaded file via JavaScript (FireFox does
this too, however, it simply cuts of the path).
I will remove this path in the widget to have the same behaviour as in
Firefox, however, you might want to create a bug to keep track of this
modification.
Thanks & Regards,
Stefan.
Roland schrieb:
> the IE8.
> Roland
Re: Path in Upload-Widget [message #137760 is a reply to message #137571] Thu, 25 June 2009 07:18 Go to previous messageGo to next message
ok thanks for looking at this.
I want to file a bug, but I don't find the link on the eclipse rap page.
Roland
Stefan Roeck schrieb:
> Hi Roland,
> modification.
> Thanks & Regards,
> Stefan.
> Roland schrieb:
>> Hi,
>> the IE8.
>> in the Textfield "C:\fakepath\file.txt" as path.
>> Roland
Re: Path in Upload-Widget [message #137772 is a reply to message #137760] Thu, 25 June 2009 08:23 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Roland,
we're currently reworking the navigation on the RAP page. Please have a
look at
http://www.eclipse.org/rap/support.php
http://wiki.eclipse.org/RAP_Bug_Reporting_Howto
Ralf
Re: Path in Upload-Widget [message #137819 is a reply to message #137571] Thu, 25 June 2009 10:55 Go to previous message
I filed a bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281481
Roland
> Hi Roland,
> modification.
> Thanks & Regards,
> Stefan.
> Roland schrieb:
>> Hi,
>> the IE8.
>> Roland
Previous Topic:Webinar: Extend your RCP App to the Web with RAP - Jul. 9
Next Topic:RAP Incubator Creation Review
Current Time: Tue Jan 25 05:25:03 GMT 2022
Powered by FUDForum. Page generated in 0.02523 seconds
