Home » Newcomers » Newcomers » Eclipse CDT - getchar/scanf(running getchar or scanf doesn't prompt input where I can type in)
Eclipse CDT - getchar/scanf [message #966450] Thu, 01 November 2012 01:45 Go to next message
Sivan S is currently offline Sivan SFriend
I took an intro programming course, but I'm new to doing this on my own.
I am running Eclipse Juno IDE for C/C++ Developers with MinGW.
For some reason, when I run the following code (from K&R) no input box shows up where I can type in my response after getchar().
#include <stdio.h>
main(){
int c;
while((c=getchar()) != EOF)
putchar(c);
I looked in the console build and found this message:
"c:/mingw/bin/../ld.exe: cannot open output file char.exe: Permission denied"
which I haven't gotten for anything else. Does anyone know where I can find the input prompt?
Re: Eclipse CDT - getchar/scanf [message #967101 is a reply to message #966450] Thu, 01 November 2012 13:42 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
> I am running Eclipse Juno IDE for C/C++ Developers with MinGW. For some
> #include <stdio.h>
> main(){
> int c;
> putchar(c);
> denied"
When new to a forum, check out the sticky posts at the top so you know
you're in the right place.
http://www.eclipse.org/forums/index.php/t/161206/
Re: Eclipse CDT - getchar/scanf [message #1805009 is a reply to message #966450] Thu, 04 April 2019 14:18 Go to previous messageGo to next message
Ali Wissam is currently offline Ali WissamFriend
I have exactly the same problem and i can't find any fix for it :(
Re: Eclipse CDT - getchar/scanf [message #1805030 is a reply to message #1805009] Thu, 04 April 2019 16:55 Go to previous messageGo to next message
Then you might also want check out the sticky note link so that you too can ask on the CDT forum..
Ed Merks
Re: Eclipse CDT - getchar/scanf [message #1805068 is a reply to message #966450] Fri, 05 April 2019 08:30 Go to previous message
ok i'll check it thank you
[Updated on: Fri, 05 April 2019 08:33]
Report message to a moderator
Previous Topic:TLS 1.2
Next Topic:[solved] how to find current context for key bindings?
Current Time: Thu Oct 01 00:37:53 GMT 2020
Powered by FUDForum. Page generated in 0.02954 seconds
