Home » Language IDEs » Java Development Tools (JDT) » Subversion wont install into Juno Win32(Subversion wont install into Juno Win32)
Subversion wont install into Juno Win32 [message #965716] |
Wed, 31 October 2012 13:04 |
Jim Hobday Messages: 1 Registered: October 2012 |
I just installed a clean Eclipse Juno and installed the updates on my Win32 XP Pro dev box. Then I installed the Google plugin and GWT toolkit with no problems.
I then went to install Subversive from the Juno site
(Juno - http://download.eclipse.org/releases/juno)
Collaboration / Subversive SVN Team Provider and
Collaboration / Subversive SVN Team Provider Sources
And I get the following error:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.team.svn,1.0.0.I20120601-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.core,1.0.0.I20120803-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn,1.0.0.I20120818-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.help,1.0.0.I20120818-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.mylyn.source,1.0.0.I20120601-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.mylyn.source,1.0.0.I20120601-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.nl1.sources,1.0.0.I20120818-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.nl1.sources,1.0.0.I20120818-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.resource.ignore.rules.jdt.source,1.0.0.I20120601-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.resource.ignore.rules.jdt.source,1.0.0.I20120601-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.revision.graph.source,1.0.0.I20120601-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.revision.graph.source,1.0.0.I20120601-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.source,1.0.0.I20120818-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.sources,1.0.0.I20120818-1700
No repository found containing: org.eclipse.update.feature,org.eclipse.team.svn.sources,1.0.0.I20120818-1700
No repository found containing: osgi.bundle,org.eclipse.team.svn.ui,1.0.0.I20120818-1700
I also tried with just the
plugin selected with the same error but obviously fewer entries not found.
I can't find anyone else who's had this problem except for a post (http://www.eclipse.org/forums/index.php/t/223929/) that was concerning Subversive 0.7.9 on Indigo. That seems to be unresolved "can't reproduce".
The only suggestion on the site is to uninstall the previous Subversive and Connectors, but the Indigo installation is in a completely separate directory and (I removed the .metadata directory from my workspace so Juno created a new one) Indigo won't even load, so I can't remove the previous Subversive or Connectors.
Any ideas on what to try?
Current Time: Thu Apr 25 09:27:41 GMT 2024
Powered by FUDForum. Page generated in 0.02820 seconds
